Simplistic NJFET RIAA - Page 758 - diyAudio
Old 28th April 2012, 07:53 PM   #7571
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by chalkandtalk View Post
Fired up today. We have music in both channels Thank you Salas.
Old 29th April 2012, 11:07 AM   #7572
Marinos is offline Marinos  Greece
Marinos's Avatar
Originally Posted by Milos P. View Post
I'm not sure. The thing is that Q1 drain on both ch. was shorting to ground
once I start tightening it to the sink. Strange that was not the case with Q4-
it stayed insulated from the sink no matter how tight it was. I know that as
my audio gnd is separated from the safety gnd by 10R-2W II 100n NPO.
My meter showed 0ohm Q1 (tightend to sink) to chassis and ~10ohm Q4 to chassis.
I have some graphite to240 pads. I purchased them (years ago) because of their astoningshly low thermal resistance.
Unfortunaly they are conductive. It was written on the specs..
Marinos
Old 29th April 2012, 01:59 PM   #7573
http://search.digikey.com/scripts/Dk...1-ND&x=10&y=18
are the ones. I was lazy to check the data sheet so I paid the price
Old 2nd May 2012, 04:22 PM   #7574
I am so surprised how good my 12.50 Technics deck sounds. Salas, your circuit is working great. The music dept, at work is chucking out a pile of classical vinyl, which I have just inherited.
I still have a slight problem with hum. However, it seems that there are quite a few causes of it besides earth loops. I thought I would need to rehouse my RIAA circuit, but maybe not.
Old 2nd May 2012, 06:01 PM   #7575
Salas's Avatar
Show some pics, maybe we can help you with routing and boxing ideas. It's been done silent many times before, there should be a better config.
Old 2nd May 2012, 08:00 PM   #7576
That's great. I'll try to get some pics up this weekend.
Old 2nd May 2012, 08:05 PM   #7577
Salas's Avatar
Do you use coax signal cable? Is a question until you show pics. If not, try that.
Old 3rd May 2012, 08:41 PM   #7578
I installed screened cable today. I also re-routed the power cables away from the RIAA.
RESULT - hum gone
Good tip, thanks Salas.
I'll still post pics this weekend.
Old 3rd May 2012, 09:51 PM   #7579
Salas's Avatar
Thumbs up. Niiiice....
The Fast Show - Jazz Club (Piles Husain) - YouTube
Old 5th May 2012, 01:39 PM   #7580
Here's my circuit.
Initially the power input was in-between the audio in and out. This meant that power had to cross one of the boards, which contributed to the hum. Power now comes in from the middle of the base.
Copyright 1999-2017 diyAudio
