Simplistic NJFET RIAA - Page 755 - diyAudio
Old 21st April 2012, 09:34 PM   #7541
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally Posted by Salas View Post
About the 30 Ohm spec of its standard buffer you are right, for BL should be ~60-70 Ohm. Looks like I had noted max spec for V type Fets that I had measured in a special build. Its an inadequate note. Should read ''under 100 Ohm with average IDSS JFETS''.
Noted.
RC
Old 21st April 2012, 10:43 PM   #7542
The mains voltage here in the UK I find is often higher than 240V. The transformer primary is rated at 230V. The net result is a higher than expected DC. I have a 30Vac transformer which gives me 51V DC which is going to be too much for the LM317. I need a 28V trannie to do this right.
Old 21st April 2012, 11:16 PM   #7543
Hi
my shunt is not regulating. LedStringV=5.45V VgsQ1=3.6V dummy load=940R VgsQ4= ~0.001VDC??? . Need 28VDC 30mA regulated. Output is like 3VDC. No smoke . Checked several times- wireing, schemo, parts values, all OK. Both mosfets(9240) are cool- not even warm. Any ideas?
Cheers
Old 22nd April 2012, 01:31 AM   #7544
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Chalk: Congrats for debugging it. Why wrap it in a chip pre reg anyway? Adding circuitry... keep it simple, it has its own input insulation via its CCS.
Milos: Your shunt Mosfet ain't open. Check orientation, health, 4 wires circuit to load, check if you got drop on R1.
Old 22nd April 2012, 07:16 AM   #7545
Thanks Salas. I only went with the Lm317 because I thought the input to the shunt needed to be regulated. The 40V comes from a CRC. If this is good enough then I can stick with my present trafo.
Old 22nd April 2012, 09:42 AM   #7546
Ricardo
you moved to Switzerland now?
Old 22nd April 2012, 01:15 PM   #7547
Orientation OK.
Health: all parts are brand new and both channels behave the same. I doubt that something is broken. It is mainly P2P, a bit p.i.a. to check, I leave it for the end if everything else (if anything) fails.
4 wires twisted connected to the load.
R1 drop 1.5V.
I feed it with 36VDC (10000uF per a ch. filtered)
Trimmer has no function, turning it in either direction produces only slight variation in voltage output which is ~3V.
Q4 on either ch. wont open.
Layout attached.
Dotted lines=jumpers.
I have no idea what to look for after about 10 hours of checking and staring
Old 22nd April 2012, 02:12 PM   #7548
Salas's Avatar
The CCS shows 150mA then. Without pulling parts you can look if all BJTs show Vbe ~0.6V, if Mosfets show Vgs a few volts, if JFET pulls some drop on its resistor in series. Change Q5 if no drop on R7, make sure R6 is connected like a rheostat.
Old 22nd April 2012, 02:13 PM   #7549
BC546b=Hfe ~360
SK170BL=Idss ~8mA
2N5457 not matched
No short gate to drain on MOSFETs
Old 22nd April 2012, 02:15 PM   #7550
Salas's Avatar
Live, vbe, Vgs, drop voltages.
Copyright 1999-2017 diyAudio
