Simplistic NJFET RIAA
Old 25th March 2012, 05:44 PM   #7471
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
I should be able to finish this up this afternoon...I will report back
Thanks for the good advice, Evan
http://www.evancotler.com
Old 25th March 2012, 05:49 PM   #7472
Since I am going to open this up to shorten the wires here is a question. What would be the smallest gauge wire that should be used. Thinner wire is easier to work with.
Old 25th March 2012, 06:04 PM   #7473
AndrewT is online now AndrewT  Scotland
post7455,
are those fuses in the bottom left corner at risk of being shorted to chassis?
Are they Mains fuses?
regards Andrew T.
Old 25th March 2012, 06:08 PM   #7474
yes, they are mains fuses, but I don't see any way for their connectors to short to the chassis. The lack of depth perception in the photo makes them look closer the chassis then they are.
Old 25th March 2012, 06:21 PM   #7475
Why two mains fuses?
Are you fusing the Neutral?
What if a short length of strand from a stranded cable fell in through a ventilation hole?
What if the screwdriver you are holding touched the exposed live connections?
regards Andrew T.
Old 25th March 2012, 06:25 PM   #7476
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Regarding wire gauge, I think that you can even go down to CAT5.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 25th March 2012, 06:46 PM   #7477
Great I have plenty of cat 5 wire. I am thinking 2 strands per connection.
I fuse both in case there is a mix up in the houses wiring. Making up the connection to one fuse or two is about the same amount of work and I saw no reason not to.
I will Put heat shrink over the exposed connections of the fuses and or a small plastic cover over the whole area.
Thanks, Evan
Old 25th March 2012, 06:51 PM   #7478
if the Neutral line fuse blows, there is a high risk that the chassis can be LIVE, even though the equipment "sounds" dead.
regards Andrew T.
Old 25th March 2012, 06:54 PM   #7479
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Marinos View Post
Hi all,
Feeding the Low MC from a 12VAC source as per pdf does the 7809 need heatsink ?
Rephrasing my question, from your experience how much dissipation the 7809 can do without any heatsink ?
It won't need one, in this case it will dissipate 90mW and it can be relatively safe for ~1W on its own.
Old 25th March 2012, 06:54 PM   #7480
There's my reason. I will eliminate the fuse on the neutral.
Simplistic NJFET RIAAHide this!Advertise here!
