Simplistic NJFET RIAA
Old 2nd February 2012, 01:28 PM   #7191
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
If building the mc pre-pre two supplies are required. It never hurts to go with more supplies, but you will be the one to judge if it's worth the effort.
Old 2nd February 2012, 01:42 PM   #7192
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Simplistic NJFET RIAA Send a message via Yahoo to vdi_nenna
Can the Pre-pre work well from a regulator for each channel and a single DC source? It's not the ultimate in seperation, but it might be enough to separate the channels. What do you think?
I build, therefore I am.
Old 2nd February 2012, 01:49 PM   #7193
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by Bksabath View Post
Tanks Merlin that is the link I was refering to and the one I used
Just wanted to post the merits where they belong.
I have made a new PCB (the drawing for it as is about 7C in the loft so not going there Today)
Is the almost standard Simplistic board on euro card size.
I have aded same loading for the cart that can be switched off
and few more mosfets at the imput.
Old 2nd February 2012, 01:51 PM   #7194
Originally Posted by vdi_nenna View Post
Is it recommended to build a seperate power supply for each channel?
If building the Pre-pre and MC phono, are 4 power supplies recommended?
Yes & Yes
Old 2nd February 2012, 01:53 PM   #7195
Yes can work, but I agree as George better perfomance with two separate PSU.
Old 2nd February 2012, 01:55 PM   #7196
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
All schemes will work. How much ultimate separation and how many PSUs is up to anyone's sense of adventure.
Old 2nd February 2012, 01:59 PM   #7197
vgeorge's Avatar
As I see it, the pre-pre needs about 15v in for it' s own regulator, or 9v if you use another one. What is your raw DC?
Old 2nd February 2012, 03:31 PM   #7198
vdi_nenna's Avatar
None at the moment. I'm just looking for a game plan on how to proceed.
A 15v-0v-15v-0v transformer for each of the Pre-pre's regulators would cover it.
Would use an approriately higher voltage transformer for the MC phono channels.
I'm not crazy about point to point wiring, because so much can go wrong, then finding the problem becomes more difficult. This is why I posed the question as to how many power supplies is enough. Having everything in mono, down to the power cord would be great, but not always possible or worth it.
thanks,
Vince
Old 2nd February 2012, 03:46 PM   #7199
R.I.P.
Originally Posted by merlin el mago View Post
Is for me your post Andrew?
Yes, the post link still takes me to post 7151. There is no pdf in that post.
post7187 downloads a pdf.
regards Andrew T.
Old 2nd February 2012, 04:50 PM   #7200
I'm sure the link I posted takes me to post 4945 where is the PDF.
If the link at the top of post 7184 not takes you to post 4945, you would learn more how to show links and post pics and etc.
Simplistic NJFET RIAAHide this!Advertise here!
