Simplistic NJFET RIAA - Page 72 - diyAudio
Old 23rd January 2009, 09:17 AM   #711
HI Salas
Is important to put the jfet face to face for a sort of thermal traking...???
Old 23rd January 2009, 10:16 AM   #712
If you want thermal tracking then instant glue the faces together and bind around the pair with three turns of thick copper wire.
I recommend that all pairs of transistors in LTPs and Mirrors be thermally coupled and that care is taken to ensure each half of the pair pass identical currents.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 23rd January 2009, 12:00 PM   #713
iko is offline iko  Canada
iko's Avatar
Default Re: Layouts
Originally posted by enzedone
ikoflexer,
Is it possible you can save those two layouts you have done in bitmap and post them up. Then I can just go over them removing the parts and print the tracks off with my laser printer and iron them on to the boards.
Brett
Brett, I can post bitmap files, sure, but I found it looses size information when printing. Nevertheless, I'll post those files a little later.
guys, about the thermal tracking, do you mean J1 from left and right channel be bound together, J2 from L and R channel be bound together, etc.? Do you really think it's worth the pcb yoga to accomplish this?
Old 23rd January 2009, 02:51 PM   #714
iko's Avatar
How about pdf? The thing to be careful about when printing the image, is that there is no shrinking of the image, or otherwise fitting it to the page in any way. The size should be left like that.
Edit: I deleted the wrongly attached file.
Old 23rd January 2009, 02:54 PM   #715
iko's Avatar
Here's the silkscreen.
Old 23rd January 2009, 02:57 PM   #716
iko's Avatar
Oops, sorry, I printed the bottom layer of the pcb as a mirror image by mistake. Here's the correct one.
Old 23rd January 2009, 03:03 PM   #717
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally posted by nicoch46
HI Salas
Not in our phono. There is no dif amp.
Old 23rd January 2009, 03:05 PM   #718
Salas's Avatar
Bravo Iko! Good sharing work!
P.S. There is already a 46dB version based on that schematic posted for high out MC 1mV for RCruz back in the thread. If someone needs another gain, let me know.
Old 23rd January 2009, 05:53 PM   #719
enzedone's Avatar
Default Cheers
ikoflexer
Sweeeeeeeeeeeet as,
I'll print these off and see which one measures up correctly
Thanks for putting the 1cm on.
Brett.
I realized that a major part of my job was to figure out how to use technology control to create economic force, or leverage, such that money and business flowed in Microsoft's direction” — Alex St.John, father of DirectX.
Old 23rd January 2009, 07:26 PM   #720
iko's Avatar
Probably the same pcb can be used, just with different part values?
Copyright ©1999-2017 diyAudio
