Simplistic NJFET RIAA
Old 22nd November 2011, 12:12 PM   #6991
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
I always keep it between 7 and 10V
RC
Old 22nd November 2011, 12:22 PM   #6992
merlin el mago is offline merlin el mago
merlin el mago's Avatar
BiB & I suppose the others regs. too:
Voltage drop across regulator: Get a transformer that for DC gives you at least 5V extra from your target voltage. 7-10V is better against mains fluctuations, transformer regulation with high current etc.
Old 22nd November 2011, 12:25 PM   #6993
nhinstruments
RCruz's Avatar
Hi Merlin
Can you please post a layout of your V12R ?
RC
Old 22nd November 2011, 12:30 PM   #6994
nhinstruments
RCruz's Avatar
Originally Posted by RCruz View Post
It works ok with MF or CF but I keep having startup issues with some of my builds.
I found that there is an inductive interaction that sometimes happens, so the shunt only starts if I touch the connection between R2 and Q2.
It is not common and I already built 14 V12R without any issues. Once it happens I need to redo R2 placement until I get it working perfectly.
Correction
The stubborn shunt fires when I touch R3 on Q3 side (Not R2 Q2 as I stated before)
I usually solve this issue by moving R3 and not R2.
RC
Old 22nd November 2011, 12:32 PM   #6995
Hello Ricardo,
The schematic V1.2R that I use.
Old 22nd November 2011, 12:43 PM   #6996
nhinstruments
RCruz's Avatar
Thank you... Now can you please post the layout or pictures of the shunt ?
I would like to compare the positions of R3 and Q3 in your shunts with mine
RC
Old 22nd November 2011, 12:51 PM   #6997
R.I.P.
I think what is happening is that your finger is injecting a small pulse to turn on the CCS FET.
A resistor + Zener across DS of the CCS FET may solve this turn on fault.
Maybe try 12V or 15V Zener and a 1k or 2k resistor.
At start up when Vout = 0Vdc and Vin = 52Vdc, with the FET OFF, the Zener will pass 18.5 to 40mA. A couple of mA will turn ON the cascode by developing a LED voltage and the remainder of that start up current starts to charge up capacitances downstream of the CCS.
Once the FET turns ON, the Vout will rise from 2 or 3Vdc to 42Vdc.
The Zener current should now be zero mA and the circuit should work normally.
Probably not the best way to ensure reliable start up. Can someone see a better way?
Will this R+Z be completely innocuous, once the CCS has established correct current?
regards Andrew T.
Old 22nd November 2011, 02:12 PM   #6998
Pic
Old 22nd November 2011, 02:51 PM   #6999
nhinstruments
RCruz's Avatar
Hi Andrew
It seems reasonable and logical.
what would be orientation of the zener ?
RC
Old 22nd November 2011, 02:52 PM   #7000
nhinstruments
RCruz's Avatar
Originally Posted by merlin el mago View Post
Pic
Thank you so much Merlin
Do you have resistors under the board ?
RC
Simplistic NJFET RIAAHide this!Advertise here!
