| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#671 |
HI Salas as I want put the Shunt in a cheap hammond alu box
how are your pcb size HxWxD of you single b+ thanks found 40vac trafo
Sic58
#672 |
diyAudio Chief Moderator
Unfortunately I did not measure its size. Maybe you can extrapolate from this picture? |
#673 |
fine ok
thanks
Sic58
#674 |
Additional inter stage coupling caps to try soon, along with the CCCP Teflons. K40-9 paper in oil 400V 0,1uF.
#675 |
I'm finally finished with my first attempt
Did the 36dB version, but need a little more gain, so next one will be the 46dB. It seems i can just lift the voltage 4 volts, and change a few resistors. Should be easy. ( well, at least for some, i always find a way to mess up, hehe ) Thanks for making this possible Salas.
#676 |
#677 |
Actually i don't know what pick-up i'm using
There's no name on it, so i suspect it's a cheap one, that someone put there long time ago.BTW, my TT is an Akai AP-306t. I know i need a new cartridge, but finances are a little tight at the moment, so i have to make the best of it for now. I'm not really satisfied with the PCB yet. I have some issues with transistors being defined wrong in the library, and some things i have to define myself. Bit of a job, me being into car-repair, and not electronics, hehe. Best regards Ebbe |
#678 |
Did you notice any better turntable replay with what you already have?
P.S. There are really cheap MM out there, considered very good. Like Audio-Technica CN5625AL. |
#679 |
This what I am using at the moment.
Manufacturer: Audio Technica Model: AT-110E Cartridge Type: Moving Magnet Output Voltage: 4.5 mv Freq Response: 20Hz - 22kHz Recommended Load Impedance: 47k ohms L/R Separation > 25db db L/R Balance < 2db db Stylus: Elliptical Cantilever Aluminum Lateral Dynamic Compliance: 15 x 10-6 cm/Dyne Static Compliance: 20 x 10-6 cm/Dyne Cartridge Mass 7.2gm Could this be used with your standard circuit This is one of those really cheap ones. ![]() Thanks
I realized that a major part of my job was to figure out how to use technology control to create economic force, or leverage, such that money and business flowed in Microsoft's direction” — Alex St.John, father of DirectX. |
#680 |
The 110 is a long going favorite indeed. But since you jumped from the extra low budget $30 CN5625AL to the $70 territory, we must also not forget to mention the Grado Black for $60.
| Page generated in 0.12568 seconds (66.66% PHP - 33.34% MySQL) with 11 queries |
