Simplistic NJFET RIAA
I've got mail
Getting closer.. These baby's should do the trick. Still waiting on a bunch of resisters. Wish I didn't have to go to work. Oh we'll I can wait.
Fit longer flexible output and mains leads. Keep the pairs twisted.
Place the EI transformer near the amp PCB.
Measure the hum on the output.
Rotate the transformer around the vertical axis and see if you can measure any variation in the output hum.
Rotate the transformer around one horizontal axis and see if you can measure any variation in the output hum.
Find the best orientation for least hum.
Now you can increase the distance, again measuring output hum.
This will give you a lot of information on what the final package should look like.
Lucas: I have found a laminated 30-0-30 transformer, probably about 200VA, in a drawer from an old Onkyo integrated amp I sued to use.
In the mains socket it measures 30.95 - 0 - 30.95
Could it be used for these FSP shunts Salas? It will save me a lot of money if I can use it, plus make me feel good about recycling.
Salas: Marra had hum from a common secondary for both bridges and shunts. Don't know, try. Keep it away from the signal runs on any account though. Big trafo = big magnetic field.
Good advice about the magnetic field. I do plan to use a separate metal box for psu.
Regarding common secondary - is that a known cause of hum, or are we just going by one experience here?
My main concern was that I will only make 43.7v less diode losses. Is that enough to power your shunts, if I use the least lossy diodes I can find?
Thanks for your patience with me!
Lucas
diyAudio Chief Moderator
Joined 2002
Its enough, especially MM builds tend to lower Rail+. I only used double mono PSUs and all the others used at least double secondaries, so the rectification & grounding scheme is devised and tested successfully on such. And its double. Marra tried once with single common secondary on the standard gnd scheme and said hum. So this is all our practical data. Don't know if it was with single or double bridge rectifiers surely though. Double is what I gathered.
