Simplistic NJFET RIAA
Old 21st July 2011, 12:31 PM   #6621
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Where do you use it ?
RC
Old 21st July 2011, 12:40 PM   #6622
R.I.P.
If the variable resistor is genuinely a "trimmer", then precision is not required and the $32 each, I see in Google results won't be necessary.
regards Andrew T.
Old 21st July 2011, 01:07 PM   #6623
nhinstruments
RCruz's Avatar
First stage Rs ?
RC
Old 21st July 2011, 01:17 PM   #6624
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
2nd
Old 21st July 2011, 01:18 PM   #6625
Salas's Avatar
I believe its very low ppm they sell at that price.
Old 21st July 2011, 01:18 PM   #6626
nhinstruments
RCruz's Avatar
Why 2nd ?
I know you already told me about that but I can not remenber the basics.
RC
Old 21st July 2011, 01:24 PM   #6627
Salas's Avatar
Its more effective since the signal is larger, and slave to the head-amp's noise so not to introduce different noise between channels. Rs in 1st is part of its noise outcome.
Old 21st July 2011, 01:28 PM   #6628
nhinstruments
RCruz's Avatar
Thank you Salas
RC
Old 21st July 2011, 02:06 PM   #6629
R.I.P.
Default trimmer VR for Rs
Then add the trimmer in parallel to the existing Rs, or in parallel to a slightly higher Rs.
eg.
Existing Rs = 30r
Proposed range of Rs +-10%
Select 36r for Rs and 1k for VR trimmer +110r fixed resistor.
Minimum trimmed Rs = 36//[0k+110r] = 27r1
Maximum trimmed Rs = 36//[1k+110r] = 34r9
Set Vr to 70r for nominal Rs = 36//[70r+110r] = 30r
Now, let's look at the sensitivity of Rs for the VR tolerance
At maximum trimmed Rs:- VR+2% gives 1020r and trimmed Rs becomes 34r89
A 0.05% increase in trimmed Rs for a +2% tolerance on the VR value.
If Rs ~+-20% is required for a gain adjustment range, then use 36r in parallel with 75r +VR= 2k
regards Andrew T.
Old 21st July 2011, 02:18 PM   #6630
Salas's Avatar
Paralleling the trimmer to a fixed resistor is a good practice indeed. Have used it like that in many occasions, for Rs here also.
Simplistic NJFET RIAAHide this!Advertise here!
