| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#6611 |
diyAudio Chief Moderator
It can be you need ground its can even.
#6612 |
#6613 |
hi
I am looking buy Elna Silmic II or Nichicon Muse (KZ) , Black Gate or other GOOD caps but anybody knows that this a store http://percyaudio.com/Catalog.pdf ? |
#6614 |
I'm Michael Percy's satisfied customer.
#6616 |
#6617 |
I have more gain in the left channel so it is natural I hear more hiss there.
I did not have time to figure it out but I will. Anyway, the FT-1 are much better than the SM I used before so they will stay
RC |
#6618 |
Welcome to teflon sound RIAA
, wich Salas schematic are you using?Felipe |
#6619 |
I am using the initial 48dB (28v) version with 33r as source resistors.
In this build I have the RC filter on the second stage and on the buffer. It is "burning" nicely and sounds better every time. ![]() Thank you for your suggestion and sampling work.
RC |
#6620 |
If you use (like I use) a Vishay 1280G trimmer, you can adjust the gain in each channel.
