Old 8th July 2011, 07:46 PM   #6601
merlin el mago's Avatar
Originally Posted by sq225917 View Post
https://www.rush-on-line.co.uk/cap_index.php
they usually stock what I need. Awful slow service but great availability..
Thanks for the good link
Old 8th July 2011, 08:49 PM   #6602
RCruz is offline RCruz  Switzerland
RCruz's Avatar
I have come across with this provider before but I never actually used it.
Merlin: If You try, I would like your opinion of course
RC
Old 9th July 2011, 10:38 AM   #6603
If I try I will let you know. Ricardo FT-1 Russian teflon caps are non magnetic like the FT-3
Old 9th July 2011, 08:08 PM   #6604
I connected the shield of both R-Core Tx to chassis more body, lows, highs, it's incredible the big improvement.
Ricardo & Nick C3 now 15.33nF
Old 9th July 2011, 08:26 PM   #6605
RCruz's Avatar
How do you like the 15.33nF
what caps are you using to make the 15.33 ?
RC
Old 9th July 2011, 08:33 PM   #6606
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
That's the correct way. Electrostatic shield goes to IEC ground prong and from there with a short cable to chassis.
Old 10th July 2011, 02:34 PM   #6607
15nF teflon aluminium foil + 330pF silver mica
thank you
Old 10th July 2011, 02:39 PM   #6608
I see both as recommended types for highest quality audio.
The parallel combination may give a synergistic boost to the audio performance of the 15n33F capacitance.
Old 10th July 2011, 02:41 PM   #6609
RCruz's Avatar
I will try that combination also
RC
Old 13th July 2011, 08:06 PM   #6610
RCruz's Avatar
FT-1 15,3nF is a real improvement over the previous SM, but I am having some trouble... After the mod, left channel has more hiss than right channel (There is a difference of 9pF between the FT-1) can this be the reason ?
RC
Copyright ©1999-2013 diyAudio
