Simplistic NJFET RIAA
Old 4th July 2011, 12:26 PM   #6581
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
I am glad you are enjoying your Salas Simplistic so much.... It sounds that good mainly due to your carefull work. Thank you so much for your efforts. I knew you would also hear the differences.
IMO the 318uS zero point is VERY important for the overall Timbre of the instruments.
RC
Old 4th July 2011, 12:33 PM   #6582
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
So what is the trimmed values network and on what gain machine? So to keep in record and measure on some opportunity. Some sketch pls.
Old 4th July 2011, 01:09 PM   #6583
nhinstruments
RCruz's Avatar
Merlinīs Salas riaa has double paralleled input jfets and works with 45v Vin.
R1 = 3k3r
R3 = 45804r // 4M99 = 45388r
R5 = 1M
So actual R3 for calc purposes should be around 46428r
R4 = 6810r // 1M = 6764r
C2 = 47.01nF
C2 x R4 = 318uS
I am not sure about C3 (15 ~16nF)
R2 under the paralleled input jfets is 15r
As he does not use the source cap bypass I guess it would produce 58dB gain.
RC
Old 4th July 2011, 01:12 PM   #6584
Salas's Avatar
OK thanks. This trimming falls almost between 1% components tolerances. Tricky.
Old 4th July 2011, 01:22 PM   #6585
nhinstruments
RCruz's Avatar
It is quite difficult to reach the correct values.... I am wondering if you could suggest a combination of smaller caps values so we could reach 15.33nF and 47nF with more precision.
RC
Old 4th July 2011, 01:28 PM   #6586
Salas's Avatar
Whatever you can combine from 1% spec caps is safer to average well near the target value.
Old 4th July 2011, 01:32 PM   #6587
Joshua_G is offline Joshua_G  Israel
Joshua_G's Avatar
How cardinal is 1% accuracy to the RIAA equalization components?
Old 4th July 2011, 01:33 PM   #6588
merlin el mago is offline merlin el mago
merlin el mago's Avatar
R1 = 3k3r
R5 = 1M
C2 = 47.01nF
C2 x R4 = 318uS
C3 15.89nF
Old 4th July 2011, 01:40 PM   #6589
Salas's Avatar
Its good to know you have made what you see on circuit reasonably accurately so to exclude unknown parameters when tuning a cart's load, VTA, VTF, etc. Or when you want to play with the filter itself a bit for your average tone with your records collection, system's tonal synergy, whatever.
Old 4th July 2011, 01:45 PM   #6590
Joshua_G's Avatar
Would 1% accuracy to the RIAA equalization components eliminate the need for tweaking values? Or is it always up to a personal taste and adjustment to the preferred tone of the entire system?
Simplistic NJFET RIAAHide this!Advertise here!
