Simplistic NJFET RIAA
Old 2nd June 2011, 02:10 PM   #6391
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Thank you Ricardo, I will send a PM to massimo to ask him if want some 15nF FT-1 so possible between 3 people will arrive to buy.
Old 2nd June 2011, 02:53 PM   #6392
massimo is offline massimo  Italy
You got a reply Felipe! (@hotmail)
Old 2nd June 2011, 04:57 PM   #6393
You also have e-mail massimo.
Old 4th June 2011, 11:29 AM   #6394
Due to the high perfomance I want to do a new single ended Simplistic NJFET RIAA for my MM Linn K9, cart specs:
Output 4.5mV
Compliance 12Cu
Coil Inductance 400mH
Suggested load capacitance 100-200pF?
I have the following NJFET stash:
2SKJ170BL
Units Idss
2 6.60
1 6.63
1 6.64
1 6.65
1 6.66
1 6.67
1 6.69
1 6.72
3 6.73
1 6.74
1 6.75
1 6.77
1 6.78
1 6.81
1 6.83
2 7.67
2 8.16
1 8.71
1 8.80
1 8.88
1 8.98
1 8.88
LSK398BL
1 6.89 + 6.92
1 6.68 + 6.57
1 6.76 + 6.93
1 6.85 + 6.92
1 7.25 + 7.02
1 7.42 + 7.50
1 8.05 + 8.24
1 8.37 + 8.77
1 8.88 + 8.58
1 8.96 + 8.89
1 9.29 + 9.28
1 9.22 + 8.91
1 9.65 + 9.54
1 8.84 + 9.11
1 8.94 + 9.01
1 9.03 + 8.76
1 10.68 + 10.84
1 10.05 + 10.27
1 11.15 + 10.72
1 10.20 + 9.97
1 11.15 + 10.90
1 11.07 + 11.08
Old 4th June 2011, 01:21 PM   #6395
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
There is the second values table in the PDF with 100R Rs change in first stage for 37dB, also described there. Use your 8.16mA pair in first stage, your 8.88mA pair for second, and your 8.80,8.71mA ones for buffers. I don't suggest load capacitance, I suggest you use only what the TT cable provides and a 100K quality trimmer instead of the 47K load resistor. That will give you many different alignments, very audible for MM cart to tune. Don't be afraid to try steps from 10K to full 100K.
Old 4th June 2011, 01:51 PM   #6396
Is this schematic changing R2 100R instead 56R also taking off 50pF Cload, right?
Old 4th June 2011, 01:53 PM   #6397
Salas's Avatar
No, this is older. Download the updated PDF following the link from post#1.
Old 4th June 2011, 02:07 PM   #6398
Now all is clear I downloaded PDF from post 4945 it's OK?
Old 4th June 2011, 02:09 PM   #6399
Salas's Avatar
Yes.
Old 4th June 2011, 02:18 PM   #6400
Perfect, now I a lot of job, thanks for support Nick.
Simplistic NJFET RIAAHide this!Advertise here!
