Simplistic NJFET RIAA
Old 16th May 2011, 06:59 PM   #6241
merlin el mago is offline merlin el mago
merlin el mago's Avatar
So I put a jumper instead R9 & disconnect C5?
Old 16th May 2011, 07:01 PM   #6242
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Old 16th May 2011, 07:05 PM   #6243
Only for your information I don't use C10, ok I will do the changes & rapport, thank you Nick.
Old 16th May 2011, 07:41 PM   #6244
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi Merlin
What is the value of the 47nF cap you are using ?
Old 16th May 2011, 07:51 PM   #6245
Before 47.1nF, now 47.0nF both channels
Old 16th May 2011, 08:00 PM   #6246
nhinstruments
RCruz's Avatar
As you use (6k8r // 1M) = 6754r
6754 x .047 = 317.44 almost = 318, I would say you are spot on the 500.5Hz mid point.
It should sound very good as is.
Let us know your oppinion if you reduce the 15,2n to 15n
Old 16th May 2011, 09:49 PM   #6247
First I will try Nick advice, if it's not enough I will try the 15nF & tell you Ricardo.
Old 17th May 2011, 02:38 PM   #6248
Originally Posted by Salas View Post
After jump R9 & take off C5 I measured again the voltages:
Left channel
Leds to gnd 7.30V
Across R17 0.259V
R10/Q2 to gnd 10.30V
R1/Q3 to gnd 11.32V
R7 to gnd 10.51V
Drain Q5 to gnd 19.85V
Right channel
Leds to gnd 7.50V
Across R17 0.285V
R10/Q2 to gnd 11.24V
R1/Q3 to gnd 11.80V
R7 to gnd 11.30V
Drain Q5 to gnd 18.80V
It's necessary to adjust R10/Q2 to gnd at 10.0V with R6 trimmer & do the measurements again?
Old 17th May 2011, 02:43 PM   #6249
Salas's Avatar
Better match channels there with R6 trimmer, yes. Also in right channel I see a bit high through R7. Its because voltage Q2 is high, but make your R7s 1.2k if you have.
Old 17th May 2011, 02:50 PM   #6250
I have 1K21?
Simplistic NJFET RIAAHide this!Advertise here!
