Simplistic NJFET RIAA
Old 19th April 2011, 09:52 AM   #6101
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Here you have Lee´s board before I started heavy modding
Old 21st April 2011, 09:00 PM   #6102
pelayostyle is offline pelayostyle  United States
Hi guys. I want to build this project soon but first would like to ask which circuit i should use for my MM AT440MLa 4.0mV cartridge. Thanks.
Old 21st April 2011, 09:18 PM   #6103
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Hi. Go back to post#1, there is a link that leads you to a PDF. Read it, it mentions to use a HiMC circuit values list there with a resistor change for real MM, if there is something you don't understand, ask here.
Old 21st April 2011, 09:47 PM   #6104
Thank you. I already found the PDF and am reading over it now. Thanks again.
Old 22nd April 2011, 05:58 PM   #6105
DARIO1997 is offline DARIO1997  Italy
Default Phono Stage
Hi Salas,
i want to assemble yor phono fet with shunt regulator.
Please, can you post all informatio for the costruction (Schematic, PCB, all components, transformer type, ecc.).
I have actualy VSPS with Sowter Transformer 9580 and Denon DL103.
Many thanks.
Mario
Old 23rd April 2011, 11:40 AM   #6106
nhinstruments
RCruz's Avatar
Hi Mario
You can find the pdf in this post: Simplistic NJFET RIAA
You do not need a TX (unless you mean the one for the psu where the best would be an R-Core)
Old 23rd April 2011, 11:52 AM   #6107
Default Riaa Salas
Hi RCrus,
yes, i mean the one for the psu.
What do you mean by R-Core?
Regards.
Old 23rd April 2011, 12:43 PM   #6108
nhinstruments
RCruz's Avatar
SELECTRONIC ::: L'univers électronique :::
Old 23rd April 2011, 01:18 PM   #6109
nhinstruments
RCruz's Avatar
As you are using a DL103, you need the higher gain version ~ 57dB so you need more voltage. The correct R-Core would be: SELECTRONIC ::: L'univers électronique :::
Wire the outputs in series so you get 36Vout from the TX.
Old 23rd April 2011, 01:57 PM   #6110
Salas's Avatar
*For DL103 he will need the PrePre+HiMC or StepUP+HiMC as described in the PDF.
Simplistic NJFET RIAAHide this!Advertise here!
