Simplistic NJFET RIAA - Page 608 - diyAudio
Old 9th April 2011, 12:32 AM   #6071
mhouston's Avatar
Originally Posted by Franz Gysi View Post
Salas
What would you change in "my" circuit to reduce to 58dB gain for the Benz ACE SL?
I just listened to an LP I know very good, and maybe, I should reduce K2 for my taste a little bit, as you mentioned before.
Franz
The B+ here is a lot higher than I would normal use. For my versions of this cct. I use 27 to 36V. I did find with my BoZ builds that the preamp sounded better with 27V and not 36. I do believe FETs like high voltages to run linear but I have found my jFET units sound batter at the 27V mark.
Old 9th April 2011, 02:19 AM   #6072
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The Fets are running much lower in that. It 'burns' it on the loads. Its not a matter of choices, it won't run for lower with its Idss, bias, and gain.
Old 10th April 2011, 06:09 PM   #6073
Franz Gysi's Avatar
I did the first comparison Benz ACE SL vs. Denon DL103R.
Loaded with 150 Ohm; gain 60dB.
As I cannot switch between both cartdridges and have to readjust the weight and anti skating, a comparison is not easy.
My first impression (Nina Simone My Baby Just Cares For Me 45rmp):
The Benz is less coloured, maybe as neutral as possible. The details are impressing, also the bass.
But I miss a little bit the voice from Miss Simone. Are the mids a little bit weak?
Not sure yet.
I will compare soon Fairground Attraction The First of a Million Kisses.
One example of the music style:
YouTube - Fairground Attraction - Perfect
I own the LP and from the same master recording the FLAC Files on my musicserver (DAC Audio Alchemy DDE 3.0).
So I can compare first the BENZ to the musicserver and afterwards the Denon.
Yesterday I've built a dustcover for the TD126.
Franz
Old 10th April 2011, 06:18 PM   #6074
Salas's Avatar
I will insist on listening to the Denon with 220R load also...
Old 10th April 2011, 06:22 PM   #6075
Franz Gysi's Avatar
Yes, I will do it. Maybe next weekend
Franz
Old 10th April 2011, 06:26 PM   #6076
Salas's Avatar
Nice cover, needed.
Old 10th April 2011, 06:38 PM   #6077
merlin el mago's Avatar
Seems original cover congrats.
Old 10th April 2011, 06:42 PM   #6078
Franz Gysi's Avatar
Nice cover, needed.
Indeed, a dustcover is a must.
In a household not only to keep dust away, but also to close the apparatus when not in use and to clean the apartement without the risk of damage of the turntable.
Thanks!
Smile
Franz
Old 10th April 2011, 08:04 PM   #6079
ra7 is offline ra7  United States
Salas and gang,
thought you might find this interesting.
[Interview] Pierre Lurné - Thoughts on Sound Propogation in arms - [English]
Check out the tip at the end of the article. Seems simple enough to try.
Old 10th April 2011, 08:17 PM   #6080
Salas's Avatar
Point contact. Good mounting experiment if there is still slack in the arm's height adjustment. I hope it will not be prone in to loosing set angles after some play and handle.
Copyright ©1999-2017 diyAudio
