Simplistic NJFET RIAA - Page 599 - diyAudio
Old 24th March 2011, 03:39 AM   #5981
The Space Egg Corp's Avatar
Originally Posted by taniknight View Post
I just bought a Tascam 58 8 track to experiment with... but that's certainly for another thread (sorry about all this nonsense Salas).
Google just taught me about Fi Audio... I guess you mean this one.
I'm working through some unusual chassis designs myself as this is probably what I'd be best at and also an area that I see is usually lacking in DIY builds. Cake tins are quaint and all, but if you are going to claim that something is as good as a $$$ unit, it should sorta look like it. Peter Daniels is on to it. Something that makes artistic sounds should look artistic to complete the picture.
Anyway, Salas, your Simplistic is great and I look forward to hearing the Itch. Maybe one day they will both make it into the kick-a$$ DJ console I'm working on (slowly).
Tani.
Hi Tani
I'm sure chassis design is a cool topic for any build thread.
Don Garber def. turns chassis design on it's head.
The constants, such as sheilding etc. remain the same, but plenty of scope is there for leftfield configurations.
My chassis are now (pre Don Garber) always built out of scrap & very leftfield parts, but adhering to good electrical principles.
Sometimes recycled material can yield a result which would otherwise be unexpected.
Obviously it must sound good, but if it looks cool it's a bonus.
Cheers
Simon
Old 24th March 2011, 04:30 AM   #5982
kstlfido's Avatar
Default Power supplies
I am gathering parts for the 1.2R shunt and the pre-shunt filter.
A while back, SGregory spelled out his filter, no schematic. I made a schematic of it, attached. How does it look? SGregory, care to comment? Does one need that many uF's to adequately pre-filter?!?
As for the shunt, I hear C1 (4.7uF) quality is critical; C3 less so. I have 2 Wima MKP 4.7uF's. But as they are 400v, I was hoping to save them for valve use. Would good PIO's be OK instead?
-Kent
Old 24th March 2011, 06:10 AM   #5983
kstlfido's Avatar
Default Resistor questions regarding 1.2R shunt
Sorry for more questions...
Are ordinary metal film resistors fine to use? I've got a good collection of the pale blue 1% types.
It looks like I can use 1/2 watt for all except for R1, which I will use a 1W resistor.
Cheers- Kent
Old 24th March 2011, 08:54 AM   #5984
merlin el mago's Avatar
Originally Posted by Salas View Post
Its essentially flat there with 33nF or 47nF too and you cut more around disc warp. Just test your 47n. You will find even 22n FT-1 very much passable with your now output caps and preamp load I believe with the real bass that is actually to be found in most records.
Thanks for the input Nick, I have to take a compromise point because my loudspeakers can't go well till 50-60Hz but my headphones go till 12Hz so I will follow your advice & first I will try with 47nF to see what's happen.
Old 24th March 2011, 10:15 AM   #5985
Originally Posted by kstlfido View Post
for the 1.2R shunt and the pre-shunt filter..........I made a schematic of it, attached. How does it look?
The rCLcLC PSU would work pretty well feeding straight into a the RIAA stage. You have ~25mF and two inductors in there for good ripple and interference attenuation.
You are going to use a Shunt regulator between the PSU and the RIAA. I think you can cut back significantly on the cost/bulk of the PSU.
That little 1nF in the middle seems a nice touch. Another (or bigger) across the secondary and across the primary might give even more attenuation.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 24th March 2011, 11:59 AM   #5986
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Cheers- Kent
Yes ordinary MF 1% are fine. R1 1W.
Old 24th March 2011, 12:38 PM   #5987
Hey Nick, with the new 47nF teflon U.S.A. sounds better than with 100nF FT-3 russian teflons & you are right I need 33nF or 22nF to cut more down the lows
Old 24th March 2011, 12:42 PM   #5988
Salas's Avatar
You see, never say never.
Old 24th March 2011, 01:05 PM   #5989
BTW USA teflon caps 200VDC are far better than russian teflon caps 600VDC
Old 24th March 2011, 01:15 PM   #5990
USA in capitals and Russian starting with lower case ! Why?
On which parameters are you basing your conclusion?
I'll re-write that sentence to get the meaning over to you.
On which parameters are you basing your erroneous conclusion?
regards Andrew T.
Copyright 1999-2017 diyAudio
