Simplistic NJFET RIAA
Old 31st December 2010, 10:15 AM   #5711
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally Posted by nicoch46 View Post
Ricardo you load the primary or sec ? there is a lot bla-bla on this ...search on AA
I am loading the secondary with 47k.
I left room for loading the primary if I need to go lower than the resulting 470ohm (1:10)
Old 31st December 2010, 10:49 AM   #5712
nhinstruments
RCruz's Avatar
Whre can I find AA ?
Old 31st December 2010, 01:32 PM   #5713
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by vgeorge View Post
A recent statement from Scott Wurcer!
Quote : Honestly, build Salas' Simplistic RIAA if you can HONESTLY tell it over a Blowtorch then get out your snowblower.
Scott Wurcer is one of the most clever engineers on the planet. He is cleverly humorous too, don't underestimate that. Keep this thread as it started, claim free.
Old 31st December 2010, 01:36 PM   #5714
Salas's Avatar
Old 31st December 2010, 01:47 PM   #5715
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
AA is everywhere around the US.
We could all use a 12 step problem of some sort.
I don't get the snowblower analogy, although we use them of course this time of year.
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 31st December 2010, 01:55 PM   #5716
Salas's Avatar
AudioAsylum is AA in this case, but to pun is fun.
Old 31st December 2010, 02:31 PM   #5717
massimo is offline massimo  Italy
Originally Posted by Joao@AltheaMusica View Post
Thanks for the info. Why 300mA?
A happy new year to all forum members here
It's accepted that the mosfet CCS works best over 200 mA. 3 complete shunt regs will draw over 600 mA. Ad I do mind the polar bear , I arbitrarily halved that value.
Feliz ano novo 2U too!
Old 31st December 2010, 03:06 PM   #5718
Joao@AltheaMusica is offline Joao@AltheaMusica  Switzerland
Thanks for the info, I've got it now!
Obrigado
Old 31st December 2010, 03:08 PM   #5719
SGregory is offline SGregory  United States
Happy New Year to everyone.
Living Life Doing the Waltz in 4/4 meter.
Old 31st December 2010, 03:16 PM   #5720
Hi Joćo
I experimented using the same shunt for both right and left channels and also one shunt per channel.
The latter produces much more separation and detail.
Ok that describes my experience as well. But the version I described makes you dance and enjoy more listening to the music. It makes better inner dynamics and rythm. Try it out.
BTW, we don't have true different mono signals as L+R channel. Mastering means to use pan pots (panorama pots) to place the groups or instruments. Think about this point.
Mono power supplies male sence in mono power amps to get smaller power supplies.
Why not use 4 shunts instead of 3 .... feed both 1st stages individually and 2nd stages individually.
Good point, but I'd recommend the opposite and feeding the output stages individually!
Why the need to feed the buffer individually ?
Make it stable and inependet for load problems, here cables to the line stage. And if you're using a passive pre, in form of a TVC, then you can drive it easily.
Um feliz ano novo. Amor, saude e dinheiro!
Simplistic NJFET RIAAHide this!Advertise here!
