| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#5641 |
diyAudio Chief Moderator
I use thin shielded for signal everywhere and always. I prefer the signal non exposed as much as it can. But I know it can escape some stuff if correctly dressed away from fields and in high enough level when in twisted pair too.
#5642 |
Well always you get something & you lost something, all depends what are your needs, but talking inside eletronics & low level signal I abosuletely prefer shielded to avoid EMI & RFI, we are talking about not long wires, for example I'm using the Cardas 2x24ga plus shiled 3mm 45pF foot/30.48cm so input I'm using 5cm (7.38pF) & output 15cm (22.15pF) compared vs interconnexion cables, Tx, chokes, power & something else using wire it's ridiculous speak of amount of capacitance in chassis shielded wires if you use the adequate, benefits to use shileded wire: avoid EMI/RFI, you choose but I have done mine.
#5643 |
Placing a DC current through the coils of any cartridge with permeable core will be magnetize !
Sic58
#5644 |
OK. Will it demagnetize if I will run random noise test LP?
#5645 |
Merlin, my 2 meter interconnect from pre to power amp has something like 60pF, if I remember correctly. If you want can check tomorrow.
Best interconnect tried, was one synergistic research a friend of mine brought to my system years ago. The ones you plug them. We could even hear when it was powered and when not, very clearly. I just can' t justify myself to give 1000 Euro for a cable. Not now, at least. I am not saying that unshielded is better, but from what I have, this is what I prefer. Salas, what thin shield cable do you usually use? I remember saying that once you used Cat5 pairs. |
#5646 |
not politcally affiliated
I use Mogami as Phono interconnects, and they are both sheilded and twisted
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE |
#5647 |
agreed on the capacitance. Never can eliminate it, only minimize it.
vgeorge, I was just implying that the very faint buzz could be other issues not just the unshielded wires. P.S. I run the same cardas shielded wire you listed when needed. Particularly on low level stuff in high fields. Sometime I can get away with interconnects that are not shield, other times I cannot depending on location of other sources.
Living Life Doing the Waltz in 4/4 meter. Last edited by SGregory; 28th December 2010 at 07:44 PM. |
#5648 |
#5649 | |
#5650 | |
for interconnects be care for power cables specially if aren't shielded.
