Simplistic NJFET RIAA - Page 561 - diyAudio
Old 28th December 2010, 12:42 AM   #5601
That makes sense AndrewT. I ran the calculation on 20r and came up with 2.00e-5W (20uW) with the 1mA current source. So I went for it.
I was about wimp out until I verified that the current was about right using my other DVM and 1000R resistor
Living Life Doing the Waltz in 4/4 meter.
Old 28th December 2010, 12:44 AM   #5602
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by SGregory View Post
Now I am curious to the sound of it with it properly loaded. I may have to pull the Pheonix out and try it.
Old 28th December 2010, 12:46 AM   #5603
I'll try it tomorrow morning. I am bread boarding the new 12b4 preamp. It is cold walking to the woodshop in 45cm of snow.
Old 28th December 2010, 12:53 AM   #5604
Salas's Avatar
Good luck with the new 12B4A.
Old 28th December 2010, 09:51 AM   #5605
merlin el mago's Avatar
Originally Posted by Salas View Post
Merlin attention. Denon 103R spec is not only misleading for compliance which we have found with FFT and test record is really 16, but also for output impedance which is also wrong and really is 19 Ohm. I measured it. Now I use 220 Ohm load and goes very fine with 1.2R fleshed out mid bass. As it happened it was nicely a bit rounded over with 150R for 1.2 and its ''faster'' tone, but 1.2R proves more musically correct as it put me in some suspicion. I will even weigh the cart If I will take it out for some other thing.
Thanks for the input, I have something to correct: in my unbalanced Riaa cap I have 15.73nF instead 15nF so I will change & tell you, I am lucky I have on hand a couple of Caddock MK132 221R so I will try & if goes Ok I will order a couple of Vishay Tx2575 nude to Michael Percy Audio.
Old 28th December 2010, 09:55 AM   #5606
+1
Old 28th December 2010, 09:58 AM   #5607
Salas's Avatar
First change the load and then play with the HF Riaa cap. Also 180R load is possible.
Old 28th December 2010, 10:51 AM   #5608
misure the cartride don't magnetize the core ??
Old 28th December 2010, 11:13 AM   #5609
I haven't 180R, I have 200R Dale PTF65. Ok first I will change the load & after the HF Riaa cap.
Old 28th December 2010, 11:53 AM   #5610
Isn't the core a magnet anyways?
Copyright 1999-2017 diyAudio
