Simplistic NJFET RIAA
Old 27th December 2010, 01:51 PM   #5561
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Having different capacitors in the phono, different TT and cart, amps, loudspeakers and room, and last but not least different individual criteria, will render each one's optimum to just another option for trying, nothing more. Its a never ending hobby, that is its magic and doom. Music is not captured in full like being there in the first place by the recording anyway. Too many mic patterns, monitoring stamps, and arbitrary production decisions destined to be reproduced through idiosyncratic transducers in homes with ten times wider the modal region of a hall.
Old 27th December 2010, 02:05 PM   #5562
SGregory is offline SGregory  United States
The V1.2R continues to open up. I stayed up WAY past my bedtime listening to it. that in itself is a good sign. I am curious as to how much it has changed since then.
I preferred the V1.2 over the v1.0 in my system. At the time that was with the Denon 103r. I had noted that the v1.0 was more laid back than the v1.2. With the new power supply, the v1.2 became even more forward, almost too much so.
V1.2r, at it's current point of burn in, is in between. I will do some more critical listening today
Living Life Doing the Waltz in 4/4 meter.
Old 27th December 2010, 02:10 PM   #5563
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Your V1.0 was with remote sense? also with V1.2R you have change your psu adding one more Tx that's is a big upgrade, all your regs sharing the same current?
Old 27th December 2010, 02:13 PM   #5564
Yes it had remote sense.
Old 27th December 2010, 02:14 PM   #5565
Same current?
Old 27th December 2010, 02:18 PM   #5566
Salas's Avatar
Do you use the same type Vref film caps in both 1.2 and 1.2R?
Old 27th December 2010, 02:33 PM   #5567
That's also important.
Old 27th December 2010, 02:36 PM   #5568
The Vref are EPCOS MKP in bothe V1.2 and v1.2R. Just different values.
As far as current, I can't find it in my notes what the current was on the v1.0. The v1.2R is running 175mA through the CCS.
Old 27th December 2010, 02:38 PM   #5569
Simplistic NJFET Phono Riaa is sensitive to current reg, so it's important to know if all regs have the same amount of current to do an objective comparison.
Old 27th December 2010, 02:49 PM   #5570
Salas's Avatar
That is good having the same caps. Only FC terminal remains to evaluate with at a point. Currents around 200mA don't differantiate as much as the vref caps. The termination caps, influence some, but the vref caps more.
Simplistic NJFET RIAAHide this!Advertise here!
