Simplistic NJFET RIAA - Page 551 - diyAudio
Old 24th December 2010, 07:35 PM   #5501
It will be Merry Christmas with the Simplistic Playing.
Merry Christmas to all.
Living Life Doing the Waltz in 4/4 meter.
Old 25th December 2010, 04:47 PM   #5502
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Originally Posted by massimo View Post
Generally speaking, the smaller (your system can support), the better. Salas is absolutely right. Check the input impedance of the following component and calculate the right value for 10 - 15 Hz.
As we are dealing with a less than perfect source, even if you cut a bit of low frequencies, is not that bad. Think about all the problem related to the warp of records and/or plinth resonance.
I am preparing a salas riaa for a friend that uses seriously undamped speakers and in my first approach we noticed that the bass cones move wildly when there is not music playing (when the needle is on the cueing part of the disc).
My initial build has 6,8uF on the output and I guess even 4,7u is too much.
Following massimo´s idea I should xcalculate a -3dB rolloff at 10-15Hz.
Pelase inform if my calculations are right:
using the following formulae: C = 159155 / (R x F)
"The 'magic number' 159155 is derived from 1000000 / (2 * pi)"
Amp input impedance = 20k ohm
Rolloff freq = 10Hz
Cout should be 0.8uF
Old 25th December 2010, 05:12 PM   #5503
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
That's what it'll do.
Old 25th December 2010, 05:27 PM   #5504
massimo is offline massimo  Italy
Riaa stage with subsonic filter.... embedded! Cute.
Only DIY can taylor a component to the system needs.
P.S. you should calculate Salas o/p imp//following amp i/p imp in your formula
Old 25th December 2010, 06:06 PM   #5505
RCruz's Avatar
Please explain in common language
Old 25th December 2010, 06:14 PM   #5506
Salas's Avatar
Output impedance is only around 30 Ohm, will not change something much.
Old 25th December 2010, 06:17 PM   #5507
RCruz's Avatar
Just for learning purposes.... can you post the correct formulae ?
Old 25th December 2010, 06:52 PM   #5508
Salas's Avatar
There is nothing more than the known first order CR high pass filter formula. Its if there is significant output impedance it forms a time constant with the capacitor that makes it appear bigger. In this case there is a buffer and the effect is negligible.
Calc.
Old 25th December 2010, 07:41 PM   #5509
Default Merry Christmas!!!!!
I like this time of year as I get a little down time from work and can focus. Starting to complete a few of the project lists I have for the simplistic.
Attached are photo's of the new power supply and V1.2R for my simplistic. After a brief break to play with some of my kids gifts, I am going to breadboard it and fire it up.
Old 25th December 2010, 07:51 PM   #5510
Salas's Avatar
Merry Xmas 2U2. Let us know how it went later.
Copyright ©1999-2017 diyAudio
