| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#5441 |
diyAudio Chief Moderator
Merlin, have you got any sketch for df_genious by the way?
#5442 |
Do you want a photo? balanced or unbalanced?
#5443 |
df_genious,
Thats the fun of it. One strip board won't work for another due the the parts selected. It is a really simple circuit so it doesn't take long.
Living Life Doing the Waltz in 4/4 meter. |
#5444 | |
#5445 | |
Ok, I connected everyting and initially both channels were working fine. But after a couple of minutes one channel the leds stoped working. Also DS voltage on Q1 stated to rise. Could you please help? Maybe problem with Q5? |
#5446 |
90% its a Q5.
#5448 |
He is referring to the LEDs feeding CCS JFET.
#5449 |
Upped the load resistor to 182R tonight. The presentation is getting back to right. Imaging is solid and tonality seems to be more balanced. Starting to notice some of the spookyness returning. Will try 220R in a day or so.
Starting to work on the v1.2R. Is the loop size as critical as the plain V1.2?
#5450 |
Loop size its easier on the R. Not to make it wide like Red Square Moscow though.
| Page generated in 0.77798 seconds (100.00% PHP - 0% MySQL) with 10 queries |
