Simplistic NJFET RIAA
Old 9th December 2010, 08:41 AM   #5341
vgeorge is online now vgeorge  Greece
vgeorge's Avatar
They are from an old group buy for BOSOZ. Each one is 4x18v. I series paralel the windinds to get 2x36. Unloaded voltage is 21v. I was using them for a year now with no problem.
Old 9th December 2010, 09:18 AM   #5342
nicoch58 is offline nicoch58  Europe
humm you can try choke input or semi.. report on tubes forum are that is way better ....
but as you do in separate box and with the great Salas stuff ....not sure
at last a resistor to reduce current charge pulse
Old 9th December 2010, 11:36 AM   #5343
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Default V check
Originally Posted by vgeorge View Post
For the RIAA - it is going to the 57db for my Shelter 901 - I have already matched some 170 BL at about 8.5mA, but I also have a stash of V's. I will measure some and see how many I can match.
Also waiting some teflon capacitors from the states.
Having a stash of V is better to be put in good use. If you can find some circa 15mA to match then you can make your phono in better input noise and interstage drive current. The RIAA values are slightly changed to be adapted and you will not need the 1Meg shunt resistor to R4 also.
Old 9th December 2010, 01:21 PM   #5344
vgeorge's Avatar
nicoch46,
I tried choke input, but got lower voltage with not enough margin to regulate for the shunt. I may put a small resistor after the diodes though.
Salas, thanks for the schematic! I will measure the V the next days and see what matches I am going to find.
Old 9th December 2010, 01:24 PM   #5345
Salas's Avatar
Some few V that I got tend around the 15mA mark so I hope yours are alike.
Old 9th December 2010, 03:34 PM   #5346
massimo is offline massimo  Italy
nicoch46,
George, try a small film cap (1-5 uF, what's handy) after the diodes instead.
That should be what nicoch intended when he mentioned you can try choke input or semi...
Old 9th December 2010, 03:42 PM   #5347
vgeorge's Avatar
I will do when I finish the rest of the RIAA. Now, I put a small resistor in front.
I would be fun to see if I can tell the diffence.
Old 9th December 2010, 04:32 PM   #5348
semi ...under 1 IMO
Old 9th December 2010, 04:36 PM   #5349
Nicoch, at first glance, I thought you were referring to semi.... conductor!
Then I realized!
< 1 uF? Really? PIO should be best in this position, possibly better than film.
Old 9th December 2010, 05:07 PM   #5350
this caps is used to adjust the Vdc out or lower the buzz from cheap choke
Simplistic NJFET RIAAHide this!Advertise here!
