Simplistic NJFET RIAA
Old 17th December 2008, 06:25 PM   #511
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
es44: Q1,Q4 are upside down on your schematic. Also C2 needs reverse polarity.
Old 17th December 2008, 06:28 PM   #512
es44 is offline es44  Denmark
es44's Avatar
Oh, i forgot to tell, that the symbols are wrong, but the legs are sitting in the right place
Old 17th December 2008, 06:36 PM   #513
Salas's Avatar
Is C2 with + looking up in practice?
Old 17th December 2008, 06:45 PM   #514
es44's Avatar
Yes, C2 and C1 is facing the same direction.
Ah, i see where you're getting at... Yes, it's the wrong way around. (blushing)
Old 17th December 2008, 07:13 PM   #515
Marinos is offline Marinos  Greece
Marinos's Avatar
Originally posted by salas
Maybe you mean Steve Bench? I haven't compared much, but I would say 95% the same. Only the tube one is much costlier and needs much more work.
Yes SB was for Steve Bench.
Could you please give your opinion about how your phono sounds on complex music passages? (rock, cuban big bands,...)
I have constructed Pacific (original + most variations published on net) and when things got complicated didn't sound any good.
Marinos
Old 17th December 2008, 07:34 PM   #516
Salas's Avatar
I don't know I never did the Pacific, and this one is developed without that in mind with some quite different basic decisions. In complex passages it never gave me any concern. There are also people in this thread that built mine with experience in listening and good systems that did not say anything about such problems. You should check it out yourself I guess and see. The shunt PSU sounds solid and smooth and big non the less, and that should help.
Old 17th December 2008, 08:44 PM   #517
Marinos's Avatar
Hi salas,
Thanks for the reply.
The schematic for the the led shunt is as post 336 ?
If yes, I think that I need your help to bring it to 36V.
Also is there any more readily available substitute for the k170s. I don't have so many of them and it seems you use them everywhere...
My line stage's input is at 47K do you think I need the buffer ?
Marinos
Old 17th December 2008, 09:11 PM   #518
jonners is offline jonners  United Kingdom
jonners's Avatar
I used the Linear Systems LSK170, but I also found some 2SK170 on eBay.
John
Old 17th December 2008, 09:21 PM   #519
Salas's Avatar
Hi salas,
Here you are. Don't go over 43VDC in, the left hand 2SK170 has 38V across already. 40V is its max.
No, you will not really need a buffer. If you notice some strain, add one. Jonners added one and said it was transparent. He has OB speakers and he is experienced.
Old 17th December 2008, 10:02 PM   #520
Marinos's Avatar
Salas you are very quick and helpfull
Thank you
Marinos
Simplistic NJFET RIAAHide this!Advertise here!
