Old 13th December 2008, 06:19 PM   #501
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Page12, post 299, has it ready for you @ 24V.
Cheers
Salas
Old 13th December 2008, 06:48 PM   #502
es44 is offline es44  Denmark
es44's Avatar
Wow, thanks a lot Salas, i missed that one, and i even read the whole thread all over again earlier today
Back to the Pcb-layout program now :-)
All the best
Ebbe
Old 17th December 2008, 05:08 PM   #503
Marinos is offline Marinos  Greece
Marinos's Avatar
Hi salas,
I would like to build your phono preamp but he thread has grown.. and reading through it makes me uncertain which schematic should I follow.
I'm intersted to the high gain version ( my cartridge is at the 0,3 mV ballamrk ) but what finally is your suggestion
- with or without cascoding ?
- shunt regulator with or without leds ? (where does the sound of batterries stand compared to the shunt ?)
Thank you in advance for your help,
Marinos
Marinos
Old 17th December 2008, 06:39 PM   #504
Salas's Avatar
Tell me about your amps and speakers so I can help you better with what may be subjectively more suitable.
Old 17th December 2008, 06:56 PM   #505
Marinos's Avatar
Speakers: 2 way (focal tweeter + 2 8"audax aerogel ) in a 84 lt reflex enclosure and minimal crossover (MTZ design)
Amps: Holton's NXV 200 Mosfet modules
Marinos
Old 17th December 2008, 07:08 PM   #506
Salas's Avatar
Use my post #110 (if you have more than 50k line in, else add a buffer), plus Led shunt.
Batteries are no good in general, even not as good as a decent series reg. You will see I used them as a test PSU when I was developing the Riaa on those earlier posts. This particular shunt is something you wanna listen to. Give it a go.
Old 17th December 2008, 07:20 PM   #507
Marinos's Avatar
Thanks salas.
Does the SB phono with your HV shunt regulator reclaim its head position sonically ?
Marinos
Old 17th December 2008, 07:23 PM   #508
es44's Avatar
Man i'm struggling here, i think i told You all, that i'm no expert, but usually i can manage.
But this one's killing me. I have made a PCB, and to my eyes, there's no errors. Is there anybody here, who would look at it and tell me what i've done wrong ?
I'm sure i have, i just can't see it after staring for hours, and comparing with schematic.
Best regards
Ebbe
Schematic:
Old 17th December 2008, 07:23 PM   #509
Salas's Avatar
Marinos:
I don't understand. SB?
EDIT: Maybe you mean Steve Bench? I haven't compared much, but I would say 95% the same. Only the tube one is much costlier and needs much more work.
Old 17th December 2008, 07:24 PM   #510
es44's Avatar
And here's PCB.
I forgot to say, that i have 1.4 volts out, and R3 gets hot. All transistors and Fet's measured just in case, they are ok.
Page generated in 0.15253 seconds (55.11% PHP - 44.89% MySQL) with 11 queries
