Simplistic NJFET RIAA
Old 16th September 2010, 10:48 AM   #4921
merlin el mago is offline merlin el mago
merlin el mago's Avatar
In my setup FT-3 interstage sounds worse combined with Mundorf SGO output (possible the guilty are Senns HD600 that have a little bass coloration), FT-3 sounds better combined with Obbligatos (fast & direct) or Auricaps (round & warm) all combos tested in my setup.
At this moment I don't listen the Amphom PIO copper foil over emphasized mids (are in break-in process could change) I'm waiting after break-in open more the highs & also continue tight & focused bass (will be perfect) but who knows will be the final sound...
P.S. congrats again your simplistic njfet RIAA is more silent (helped with R-Core Tx) that my Linn Linto & the Linto is considered by the majority of people the most silent commercial phono preamp.
Old 16th September 2010, 11:02 AM   #4922
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
That is why they call it subjective preferences. All those parts mentioned are excellent in general for what they are or for cost to performance ratio. A different TT, amp, speakers, even peripheral parts to the caps like your own choice resistors, can make different soups. Enjoy as you like best. Cheers.
Old 16th September 2010, 12:41 PM   #4923
records33 is offline records33
Default Hello everybody,
I am also a Analogue Source enthusiasts, want to share with friends
Old 16th September 2010, 02:00 PM   #4924
You are welcome
Old 17th September 2010, 08:18 AM   #4925
Joao@AltheaMusica is offline Joao@AltheaMusica  Switzerland
[QUOTE=merlin el mago;2304857]In my setup FT-3 interstage sounds worse combined with Mundorf SGO output (possible the guilty are Senns HD600 that have a little bass coloration), FT-3 sounds better combined with Obbligatos (fast & direct) or Auricaps (round & warm) all combos tested in my setup.
QUOTE]
I'd like to give the GE caps a try - type Z97F5011, PIO-caps with no PCB. Good sounding caps, normally used in PSU. Another suggestion are Aerovox caps.
@ Salas:
Have you tried the J308/310 JFets instead of the SK170? They have a Ciss of ~ 5pF...
Old 17th September 2010, 08:23 AM   #4926
Salas's Avatar
I have used some in cascodes in psus. Their 6nVsqrtHz en is no good for the phono.
Old 17th September 2010, 11:32 AM   #4927
Default Interstage Caps
Aaaaarg, when changed the headshell leads to Cardas 33ga with premium PCC Ag/Rh clips I forget to change the VTF so the cart was working with a lot of more weight: finally reached the reason FT-3 sounds bad in interstage position combineds with Mundorfs SG PIO as output cap, now the clear winner is FT-3, yes the cheap FT-3!!! but at this time Amphom copper foil PIO aren't yet finished the break-in period. I do the test with classical music & now I understand the reason bad sound due to the fact FT-3 are so dense with real deep lows, hyper detailed mids & transparents highs combined with the Mundorfs SG PIO as output cap (the extra weight increased bass & mids to a level of distortion area & missing highs). Will see when Amphoms copper foil PIO where finished break-in time, now the sound is as found in a good paper-in-oil cap: the treble rolloff and bass slowness vs FT-3...
Old 17th September 2010, 08:09 PM   #4928
SGregory is offline SGregory  United States
Merlin,
I am glad you worked it out. If I understand your comments you now like the Mund SG and Ft-3 combo.
I am getting ready to measure the simplistic finally. Finally sorta figured out the 1616m interface and have been able to obtain some decent direct connect noise spectra. Attached are the before (MAudio) and the present measurement system (EMU1616m). Night and day!!!! Will be interesting tosee what the riaa will look like with all of the issues I have had in the past with ground loops.
Both are calibrated for 1Vrms = 0dB
Living Life Doing the Waltz in 4/4 meter.
Old 17th September 2010, 08:43 PM   #4929
Salas's Avatar
That EMU looks like a 20dB better noise floor card than the M-Audio. Good investment for a stationary PC it seems. What is its best online price currently?
Old 17th September 2010, 09:17 PM   #4930
It was just under 400
Simplistic NJFET RIAAHide this!Advertise here!
