Simplistic NJFET RIAA
Old 1st September 2010, 06:52 PM   #4651
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by SGregory View Post
The truth is that Merlin is still at half the price of an equiv commercial RIAA. Plus he can fix it so no service calls.....
A solid POV also.
Old 1st September 2010, 07:00 PM   #4652
merlin el mago is offline merlin el mago
merlin el mago's Avatar
I tweaked several high-end for me & for mine friends:
CD transports: Teac P700, CEC TL-1, etc
Tube amps: Jadis JA80
Pre amps changing volume control for stepped attenuators, output caps, etc
So is a long way do it & learned how sounds each component depending where used.
I'm not in competition with commercial products, here in our DIY world exist the pleasure to share, learn & enjoy with all the community & that's it's for me same important than do & very good phono, if I know you before for sure I saved a lot of money buying commercial products.
Old 1st September 2010, 07:01 PM   #4653
Originally Posted by Salas View Post
A solid POV also.
Sorry mine ignorance what's POV?
Old 1st September 2010, 07:03 PM   #4654
Salas's Avatar
Point Of View.
Old 1st September 2010, 07:05 PM   #4655
Some say the 103R has the most coherence anyway, but I think although boxing far above its weight, then is the top Shelter, then the Transfiguration, then the top dollar handful of myths.
You have lucky: you have a clear idea what do you want, a lot of people don't know what he want's & spends a lot of money looking for.
Old 1st September 2010, 07:08 PM   #4656
SGregory is offline SGregory  United States
Merlin,
I meant my comment to be a compliment to your pursuit of excellence. This is certainly a worthy circuit to invest time and effort into.
Living Life Doing the Waltz in 4/4 meter.
Old 1st September 2010, 08:36 PM   #4657
SGregory, don't worry I understood your post like a compliment for me thank you.
Felipe
Old 1st September 2010, 08:43 PM   #4658
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi Merlin
I am sure it was money well spent !!!
I really apreciate your subjective impressions about different components.... Would you please replace the output caps and let us know the outcome before you go for the interstage ?
Old 1st September 2010, 08:44 PM   #4659
I meant in your stash Andrew.
I have only a very small batch of 2sk170gr. Most of mine are LSK170a. As far as I can recall no more than 1% fell outside grade range.
Except, when I got to LSK170C. Many in this grade were what I called C+ and these are roughly equivalent to 2sk369v.
I have bigger batches (200 off each) of 2sk170bl and 2sj109bl. So far I have not found any outside grade range.
regards Andrew T.
Old 1st September 2010, 08:52 PM   #4660
Salas's Avatar
It could be the factory mislabelled or mixed some batches and gave special prices to some vendors?. Don't know, excluding any error during measuring of course. If they are genuine, is not bad that Dual Triode got some strong ones too. DT, can you photo some on macro so we can see the labelling and if it looks genuine? You used the Ameter method with no drop resistor, right? What is the tolerance of those Ameters?
Simplistic NJFET RIAAHide this!Advertise here!
