Simplistic NJFET RIAA
Buzz, check item 261150895343 on ebay. Those 0.047uF FT-2 teflon caps are quite compact (31 mm long, 20 mm dia) compared to the usual ones.
"Silver plated steel leads."
Steel is usually a bad thing to conduct audio.
You may want to open them up and repackage them with epoxied ends and better wire leads.
There is a a thread about doing something like this somewhere around here.
Supposed to help and reduce the size.
I have a few of the larger ones and will eventually take one apart.
Rush
Joined 2006
Rush
Did not know about the steel ends... Anyway they sound splendid.
looking forward to your cirurgical experiments.
Joined 2009
Could I use 2SK246BL in place of BF245A?
diyAudio Chief Moderator
Joined 2002
Dual 170BL is 65dB, if I remember correctly. 63B is for 369 version
No, dual K170BL is ~60dB, single K369BL is ~57.5dB. Dual K369BL could go 63dB if redesigning especially for LMC. To reach ~75dB I would choose single 369BL driven by 20dB SUT. Don't know about input overload there though. Could couple to an on board amplifying stage than to the output buffer stage is better I think.
