Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#4571 | |
diyAudio Chief Moderator
![]() *You could try those filter curves taken without the correction file too. Not sure how they tie when the card goes at low dB. If they were plus 1dB off in the highs it would have been subjectively very annoying too. You should centre the curves on the plot at 1kHz not 20Hz, as well. They normally deviate both sides edges where the card wimps out a bit. |
#4572 |
R core will fit perfectly well in the PSU enclosure. I didn't want to split the chassis initially as I was waiting for the Ultimate RIAA to do that with. This is pretty close, I won't be shopping for a while.
Listening to a 1/2 Mastered version of Weather Report 8:30 live from Tokyo. I am about in the 5th row center. The sax was walking across the stage during a solo. The system is pretty flat from about 20 to 20k with the MAudio. Another reason I stayed with it.
Living Life Doing the Waltz in 4/4 meter. |
#4573 |
Some vinyl through this contraption can be quite eerie sometimes. I have some Zappa with the London Symphony, can take you aback.
#4574 | |
#4575 |
#4576 | |
Hello,
This seems like the project and good people to develop the tools and skills with. I just swapped out metalized PP capacitors in the tube line buffer for Russian NOS Paper In Oil. Take Five never sounded so good! DT All just for fun! |
#4577 |
SGregory nice work , eddy current trick
#4578 |
Nicoch46 so where did your line-out go? Is it now wireless;->
Salas, Would my current set-up with the now seperated PS benefit from a small buffer Cap on the shunt reg? I was thinking like a 4.7uF PP on the 52V DC in?
#4579 |
It could, but I would just use up to 100n fast one.
#4580 |
I have those K71 teflons that may be a good home.
New To Site? | Need Help? |
