Simplistic NJFET RIAA
Old 21st August 2010, 12:29 AM   #4521
SGregory is offline SGregory  United States
Saw the same thing using Arta. Installing drivers for the E-MU 0404. Lets hope for better. I want to get a good set of measurements on the RIAA
Living Life Doing the Waltz in 4/4 meter.
Old 21st August 2010, 12:39 AM   #4522
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The resolution is good. The Riaa will hover higher anyway. Any residual tip stuff we can count out now we saw the raw loop. No worries. But its a nuisance you can be better off cleaning if possible with the EMU.
Old 21st August 2010, 03:19 AM   #4523
No Joy. WIll have to work on it tomorrow
Old 21st August 2010, 05:42 AM   #4524
Technically it is tomorrow I guess. Found the issue with the sound card, it was the driver. Took me many hours of frustration to find it. Back to M-Audio card as it has a lower noise level in this set-up.
Taken at 48000, 65536FFT Blackman. 0dB = 1Vrms
Old 21st August 2010, 08:51 AM   #4525
Salas's Avatar
I guess thats clean enough. Congrats.
Old 21st August 2010, 12:03 PM   #4526
R.I.P.
in your previous plots the 60Hz and the +-180Hz sidebands on the 1kHz were almost certainly mains and intermodulation with the third harmonic.
Your latest seems to have lost that mains interference.
regards Andrew T.
Old 21st August 2010, 12:51 PM   #4527
I agree as it makes perfect sense, but the only real difference between the good and bad was the software.dll used for the signal generation. I was able to repeat the same results and symptoms this morning.
Why is the third harminic so dominant?
I ask this as I have the RIAA hooked up right now. I don't see sidebands to the signal but I do see 60,120,180..... with the odd harminics spraying up into the higher freqs.
Old 21st August 2010, 01:01 PM   #4528
R.I.P.
I don't know why the odd harmonics become so dominant. But they are the source of the buzz we hear when the PSU to Amp connection is not quite right.
regards Andrew T.
Old 21st August 2010, 01:10 PM   #4529
Salas's Avatar
Or show low level oscillations.
Old 21st August 2010, 01:22 PM   #4530
How much of the issue could be related to incoming power quality? Just put my probe on the AC line-in and it looks like a triangle wave with the tops and bottom cut off tp fit it into 120V.
When I look at the harmonic spectrum closer it kind of looked like a triangle spectrum.
Simplistic NJFET RIAAHide this!Advertise here!
