Old 14th August 2010, 05:07 PM   #4391
merlin el mago's Avatar
It's necessary also to connect the NJFET RIAA to the regulator?
Old 14th August 2010, 05:08 PM   #4392
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Connect the 1k5W as load to the regulator, its enough.
Old 14th August 2010, 05:45 PM   #4393
R5 270R 1W burned
Old 14th August 2010, 06:29 PM   #4394
Salas's Avatar
You have done damage in more semiconductors than Q5 in your previous experiments it seems. That one resistor burning is fishy for knocked out BJTs in the CCS tail governing the LEDs current. Seek and replace all damage in the reg patiently.
Old 14th August 2010, 07:07 PM   #4395
Ok I will change BJTs, the leds lit orange instead yellow when resistor burned. Thanks
Old 14th August 2010, 07:10 PM   #4396
Originally Posted by Joao@AltheaMusica View Post
there exist CDPs / DACs which deliver up to 6Vac ...
I am not aware of this standard.
Could you mean 6Vpp?
regards Andrew T.
Old 15th August 2010, 12:57 AM   #4397
Tubie Noobie
Merlin, I would recheck the LED's as well, makes sure they are still matched. A color change isn't a good thing in an LED since they are typically mono-chromatic unless it is designed to do that. If not, the junction was over heated. The Orange glow was probably thermal emission and not normal.
In regards to the gain comment presented earlier. If there was more gain than the 58dB I allready have, my speakers would have glowed like the LED above at the same volume settings as my cd player. As it stands now, my volume control is very much in the same range as my cd player for the same volume.
I have some pictures coming of the DL103r on the arm and comments on the RD80 mod. The mods I did were in the wrong direction so don't get too excited.
I spent the day redesinging my 12b4 preamp. It was an old project using bird nest and dead bug technique. The bugs started to rot in the nest, if you know what I mean. I put the tube on a 10m45s CCS load with LED bias. Working well so far, at least the gain between channels is closer.
Living Life Doing the Waltz in 4/4 meter.
Old 15th August 2010, 01:53 AM   #4398
Salas's Avatar
Did you notice any rise in hiss when anode loading with the IXYS?
Old 15th August 2010, 02:19 AM   #4399
Tubie Noobie
No. Actually a reduction of hiss. Quite a bit in fact. I remember your comments on the OPUS thread and was wary at first. I did have some tubes that were not stable with this.
I would like to build a discrete CCS for it at some point. Still looking for a good design.
I don't want to get OT however.
Old 15th August 2010, 02:24 AM   #4400
Salas's Avatar
I had some 12B4s that would hiss with such an anode load but it is not the norm as it proved by asking around. Thanks for the info.
Look around the forum for gyrator constant voltage designs too.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Page generated in 0.12650 seconds (67.99% PHP - 32.01% MySQL) with 11 queries
