Simplistic NJFET RIAA
Old 30th July 2010, 12:02 PM   #4241
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by RCruz View Post
Well, the GND layout is the same as before and I did not have any hum with the v1.
With the v12 fullfilm I hear a slight hum when at full power and no signal in.
I guess the big caps are picking up from the nearby psu lines.
I believe it is a field because the hum is greatly reduced just by closing the riaa case lid
But the very V1 layout on its own board maybe had some tighter ground? But the lid surely is a strong sign you got to shield first.
Old 30th July 2010, 12:03 PM   #4242
Salas's Avatar
Originally Posted by SGregory View Post
Joao, What variant of the sk170 are you using? GR= 3-7 BL = 6-12, and V= 10-?. I was curios, if I could find the V variant it may eliminate the need for a buffer all together and still have a reasoably low impedance.
Don't eliminate the output buffer. Then your Zo will be second stage's load resistor no matter the current in that stage.
Old 30th July 2010, 12:07 PM   #4243
R.I.P.
I wonder if this is telling you that a flow and return of a circuit are separated creating a large loop area. That loop area then picks up the field and generates a voltage that you hear as hum.
LOOP AREA is critical in attenuating interference, both at source and at receiver.
regards Andrew T.
Old 30th July 2010, 12:20 PM   #4244
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi AndrewT
Would you explain this LOOP AREA idea?
(flow and return of a circuit are separated creating a large loop area) ?
Old 30th July 2010, 12:47 PM   #4245
SGregory is offline SGregory  United States
I was going to eliminate the buffer. Would have to find a V variant first, which is like trying to find a Hens tooth.
Living Life Doing the Waltz in 4/4 meter.
Old 30th July 2010, 12:47 PM   #4246
R.I.P.
the circuit supplying power to your active amplifier arrives via two wires (dual polarity requires three wires).
The current from the PSU flows through one wire and returns via the other wire. That is what makes it a circuit, a circular route.
If the flow and return wires are separated then the loop area acts as a transmitting aerial sending interference out for any other circuit to pick up.
Minimise the transmitting loop area by keeping the circuit short helps, but this cannot be made infinitely short.
Twisting the two flow and return wires together has the effect of canceling the transmitted field for all other circuits that are a significant distance away, compared to the gap across the twisted pair.
A similar aerial effect occurs with input circuits. The Flow and Return must be closely coupled and preferably short to minimise the loop area between the wires forming the circuit. A bigger loop area will act as a more effective receiver aerial.
All electronics depends on circuits.They all have a flow and return route. The current must return to it's source, otherwise it is not a circuit. The layout design for all electronics should take account of the flow and return routes for effective interference attenuation and also for parasitic effect attenuation.
It is very possible that your V1.0 and V1.2 layouts (both PCB traces and external wiring) were implemented quite differently. If V1.0 performed well you need to replicate what was good about it's layout when implementing V1.2
LOOP AREA is critical.
regards Andrew T.
Old 30th July 2010, 12:51 PM   #4247
Salas's Avatar
The only thing that a V will do is that it can run more current so to make the 2nd stage's drain load resistor smaller for same gain given the same B+. Still it will be kOhm. Without a buffer its too much. Done that, the buffer plays better. That is why there is buffer in Franz's although he used V all over.
Old 30th July 2010, 01:05 PM   #4248
nhinstruments
RCruz's Avatar
Thank you Andrew.
V1 and V12 layout are very similar in my case.
I believe the big caps are picking extraneous fields. I will implement the mic wire and report
Old 30th July 2010, 01:09 PM   #4249
Salas's Avatar
And by enormous size they widen the loop area.
Old 30th July 2010, 01:14 PM   #4250
I need to read my posts better. That was suppose to say "I wasn't going to eliminate the buffer".
I want to build the circuit per your prescription. No modifications. Sorry for the confusion.
Simplistic NJFET RIAAHide this!Advertise here!
