| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#401 |
diyAudio Chief Moderator
After some experience with topology and extended auditioning has been gathered by my friend Michael and me on this Riaa, we can say that using cascode on all stages is giving just different and not necessarily better results. Cascode with BJT sounds more detailed, when just common source sounds less detailed but more fluent. Its a system and recording dependent thing. With push pull amps and multi way speakers, cascode can detract towards hyper detail on some recordings. Its probably serving better SET and full range. MadK urged us in his thread to fully cascode the thing, probably does very good match in his system. Me I will keep on using the 2 stage simple common, I prefer it. My line in is 100k so no buffer.
I guess that a proof mix is what Lee makes. I.e. First stage cascode to preserve detail and can accept any MM cart, second stage just common source not to overcook detail , plus a source follower buffer to keep composure in all driving circumstances. |
#402 |
Hi Salas-
I am starting to gather parts for your shunt reg on post 219 (the first one) to go with your RIAA design on post 110. I'm a bit of a noob to silicon... I'm trying to source from one supplier (Mouser) here in the US. I've found BC550 and BC560 but with different suffixes; does that matter? Is there a US equivalent to the IRFP9240? Mouser has none. Caps- I've got some nice little Siemens styrenes for the 47pF and Leclanche styrene for the 100nF. I was thinking about picking up some of those Russian green styrene caps and the FT-1 teflon 1000pF to trim. Any good results with these? Thanks! -Kent |
#403 |
Hi Salas -
There's something I don't understand about the component values for the buffer, and since I prefer to understand what I'm doing rather than blindly follow a schematic I wonder if you might help? Taking your buffer in post 236 as an example: The gate of the buffer fet is presumably at about 8V, same as the drain of Q2. As I understand it, the source has to be more positive than the gate, so the source voltage must be more than 8V. The source resistor is 680R, so the current must be at least 8/680 amps, i.e. 11.8mA. This seems like a lot - is my reasoning correct? Thanks, John. |
#404 | |
Mouser also has styrenic caps -- helps to have their paper catalog. I order from them every week. |
#405 |
The BCs might have some suffix like A, B or C according to the hfe (C is the higher).
If you don't want to use the International Rectifier (now part of the Vishay group) IRFP9240, you can try the Farchild equivalent FQA12P20 (the same now suggested by Nelson Pass for his latest design) available at Mouser. Both are proudly designed in USA. |
#406 | |
The Q1 drain voltage ~Zener-600mV. The source voltage ~33*Id The gate voltage ~0Vdc. Vgs=-source voltage
regards Andrew T. |
#407 | |
Hi Andrew. I get that, but I was actually referring to the last stage, Q5. John |
#408 |
working from the output: Q5 Id should be < Idss i.e.<=7mA. Q5 source will be ~ <=4.7V. Q5 Vgs will be ~<=0v (since it is passing near Idss). Q5 gate and Q2 drain will be ~ <=4.7V. Q2 Id will be ~ [36-4.7]/[100+6k8]~=4.5mA Id = Idss[1-{Vgs/Vp}]^2, take a guess that Vp~-1V and Vgs~-550mV. Id~=5mA. back to the the guesses and actual Id=4.5mA. giving Vs~ 150mV (33*0.0045) It seems that Vgs ~ -540mV and Vd ~ 4.7V therefore Vg ~ -390mV. can anyone confirm the calc and logic?
regards Andrew T. |
#409 | |
Thanks people for your replies to questions, you covered greatly.
#410 |
Salas,
are you running Q5 @ 150% of Idss? or using a higher Idss than the 7 to 8mA shown?
regards Andrew T. |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Page generated in 0.16389 seconds (69.93% PHP - 30.07% MySQL) with 11 queries |
