Simplistic NJFET RIAA
Old 4th July 2010, 06:02 PM   #4071
kstlfido is offline kstlfido  United States
kstlfido's Avatar
FT-3's are foil. Don't know how to tell if it's aluminum or tin; looks like aluminum.
Been lurking on this thread. Will get back to my salas MC pre in the fall. I will incorporate maximus's LDR (which sounds great).
Old 4th July 2010, 08:58 PM   #4072
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
maximus´s LDR ?
Old 5th July 2010, 01:34 PM   #4073
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Thks for the info
Old 6th July 2010, 07:40 PM   #4074
kstlfido's Avatar
Rcruz- search for the Lightspeed attenuator thread. In that thread, search for "LDR remote control" , author "Maximus".
I am going to use the Salas RIAA, but using the Salas symmetrical buffer at the end, instead of the source-follower. Then this would go into the LDR vol. control.
Salas, does that sound like a usable arrangement?
Cheers- Kent
Old 6th July 2010, 07:45 PM   #4075
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
I just actually incorporated an AC coupled B1 like in the output of my test LMC shown prepared recently in a few pages back, and it does very well fed to a Mezmerize between the KT88 triode amp. I think its good to avoid the integral buffer if you know you have a buffer next, but I would still use one if it will have a low input impedance LDR lower than 20k equivalent pot to drive. Don't forget to size your phono Cout according to what impedance it drives in your set.
Old 9th July 2010, 12:11 AM   #4076
NPower is offline NPower  Portugal
NPower's Avatar
Question Noise ??
Hello Salas, right now I finished mine Salas SJfet, and I love the sound of this
Everything looks ok except one thing, when I crank up the volume ( say 1/3 of volume) I get background noise (noise is the same even if I disconnect the turntable). Is not hum, this noise sounds like when we have the stylus on a track without anything recorded on that (like the end of the record). Right now I'm using a double shunt psu (only transformer rectifier and filtering are common).Any idea?
Performance is a state of mind !!
Old 9th July 2010, 12:16 AM   #4077
Salas's Avatar
Look with an oscilloscope that your power lines are clean first. What was the version of reg you used?
Old 9th July 2010, 12:26 AM   #4078
NPower's Avatar
This one, by the way I'm getting 37.5 V on output.
Old 9th July 2010, 12:30 AM   #4079
Salas's Avatar
This one is very difficult to get it oscillating. Still take out that 0.1uF across B+ on the phono boards. Also give me the voltages you got on all drains and collector. Have you got an oscilloscope? Is this thing sounding like a grunge (low to medium frequency boiling like)? What is the gain of your preamp?
Old 9th July 2010, 12:31 AM   #4080
NPower's Avatar
This is the PCB
Simplistic NJFET RIAAHide this!Advertise here!
