Simplistic NJFET RIAA
Old 15th June 2010, 08:53 PM   #3941
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Fantastic results.
Did you use NOS BG or did you save them from previous experiments ?
If these are NOS, how long did you burn them in ?
Old 15th June 2010, 11:10 PM   #3942
merlin el mago is offline merlin el mago
merlin el mago's Avatar
No aren't NOS, are from older projects so are burned.
Imagine the BIG change BG does that now I have to adjust the value for C2 RIAA capacitors: after 16nF024 now 15nF977 & possible will finish 15nF930 or less.
Old 15th June 2010, 11:12 PM   #3943
acidbrain is offline acidbrain  Netherlands
acidbrain's Avatar
So they are BOS ? burned old stock
Old 15th June 2010, 11:52 PM   #3944
nhinstruments
RCruz's Avatar
BOS might be even better than NOS
Everything depends on the burning.
Old 15th June 2010, 11:57 PM   #3945
nhinstruments
RCruz's Avatar
Originally Posted by NPower View Post
Just finished my main PCB according Salas instructions.
I attached files for main, copper and silkscreen in PDF format.
Right now I gonna prepare my self to etch my first PCB.
Nice work !
Please post some pictures of the pcb (after you etch them).
Old 16th June 2010, 08:41 AM   #3946
Franz Gysi is offline Franz Gysi  Switzerland
Franz Gysi's Avatar
Nice work !
Yes, it looks good.
But a comment to the grounding: afaik it is not good to change from wide traces to narrow traces and vice versa.
Specially not when currents are flowing, what is the case for the grounding, specially between the bypass caps.
Franz
/Edit: try to explain (afaik): different size of traces is resulting in minimal differences of conducitvity eg. resistance. When currents are flowing this will produce voltage differences on the grounding traces. And this is to be avoided. Better use one trace width, as large as possible.
Old 16th June 2010, 11:44 AM   #3947
The burning was doing with 1st quality wood (ebony) & slow fire to cook the cap as better as possible.
Old 16th June 2010, 11:52 AM   #3948
nhinstruments
RCruz's Avatar
You did not forget the garlic did you ?
Old 16th June 2010, 11:55 AM   #3949
massimo is offline massimo  Italy
@NPower
In your pcb I don't like IN gnd + RL gnd not referred with thier own track to star gnd. If you connect them to D4 gnd and R2V gnd, you mix up Signal gnd and Power gnd. Not good at all.
Take example from OUT gnd and R8 gnd: correct routing.
Plenty of space to fix this problem....
Old 16th June 2010, 02:55 PM   #3950
I forgot thanks for advice I will do "a la llauna" catalan typical foot
Simplistic NJFET RIAAHide this!Advertise here!
