Simplistic NJFET RIAA
Joined 2009
1Khz sine wave, probe x1 left channel
diyAudio Chief Moderator
Joined 2002
There is a mystery then? TT plays confirmed, pre-pre measures confirmed, Partridge is a confirmed passive component, Rotel works from MM confirmed, but when you chain TT either from pre-pre or Partridge to Rotel you get nothing. I can't find logic in this. There is something done wrong.
Joined 2009
Good & bad news.
Good news: channel left is sounding with a big buzz
Bad news: channel right don't sound nothing as is not connected
I reversed the channels at the input Rotel MM and....only sounds always left channel with big buzz so Low MC pre-pre is sounding both channels thi make sense because the same problem was with the step-up combo, I have to wait until I have finished the Itch:mad:
Joined 2009
For start, I would remove all ground wires from the rca to the chassis and check.
Then one wire from the star of your circuit to the chassis.
These are just suggestions, I would recomend to try various grounding arrangements and see.
I have to ground stars one for each channel, have I to connect the two ground stars togheter & after one wire to chassis or have I to connect two wires (one of each channel) to the chassis?
