Simplistic NJFET RIAA
Old 1st June 2010, 04:09 PM   #3781
Franz Gysi is offline Franz Gysi  Switzerland
Franz Gysi's Avatar
Salas
I forgot to change the value of R1/R101 in the drawing, but I have prepared two 2k2 resistors.
And in my circuit, board, I have the resistors C9a/C9b to stabilize the first stage.
Juma
Of course, I did knew, that LM317 can be used for higher voltages, also for tube amplifier supplies. It is the max input/output difference limiting their use.
But: it will be more noisyer due to the zener or diode.
Franz
Old 1st June 2010, 04:34 PM   #3782
NPower is offline NPower  Portugal
NPower's Avatar
Hello
This is my first post and first of all I would like to give my congratulations to all the people who contribute to this wonderful forum, and a special congratulation to Salas on this thread.
Well I decided to build one of this phono pre amplifier, it's s for a Audo Technica AT31E, so I pick up all the components and design a new PCB according thread info.
Yesterday I decided to etch my PCB'S but first I decided to check the forum for some news concerning this project, and I realized there is some modifications, so i have some questions.
My schematic is K170BL IDSS8-9mA Gain 56db MC.
- I want to use paralleled Q1 with also a paralled R2, should I use 33R on this ?
- I gonna change the position on schematic for C1, so I need to use R17, but, how about R1-6,2K and R3-43K, should I keep that values ?
- What is the correct value for RloadX, 1K on the schematic , right now I see some schematics with 150R.
- And last one, how about R6-27R, should I change it to a trim pot ?
These ones are not finished yet, but I will post the new ones ASAP.
Performance is a state of mind !!
Old 1st June 2010, 04:46 PM   #3783
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi NPower
Can you post the schematic you are refering to ?
Old 1st June 2010, 05:00 PM   #3784
NPower's Avatar
Hello RCruz
This one , but with the correct values for MC 56db
Old 1st June 2010, 05:10 PM   #3785
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by NPower View Post
Hello
Those are not modifications exactly, those are tweaks so to get a 60dB circuit for low MC at same noise level as the 57dB.
Your cart is 0.4mV and the 57dB you draw will serve it rightly.
Leave R6 as it is, make R7 1k2 instead of 1k. Use 100R trimmer for R2 instead, so you can match the two channels for 10V at Q3's collector.
RloadX is only a general value when we don't know the specific cart that will be used. Those 150R were recommended since people who asked for LowMC had the Denon DL103R. Yours looks like will be happy with 100-150R. But this is something you got to listen for, maybe you can install pins for exchanging that resistor easily on tests.
Changing the BC550 base decoupling tied to B+ is an option said to improve PSRR. Regulating the LEDs current lower with a 100Rs is good for the Q6 JFET's dissipation.
R1 & R3 you must not change, they are crucial values for the Riaa filter.
Old 1st June 2010, 05:24 PM   #3786
Salas's Avatar
Originally Posted by Franz Gysi View Post
Salas
Franz
Yes, but I see it wired before all other RC, when to decouple 1st stage from the others it would need to serve only stage 1 as I have shown in that little example I cropped and attached. I stopped using that when with V1.2 Reg so not to impose the electrolytic ''signature'' but it really depends on how the remote is wired in relation to first stage, and in your case it maybe better to have. You can always listen with or without that RC and decide. I don't know with that circle GND trace or local stars connected to a main star, I would thought it will be easier to debug hum issues if having stage sub stars. If we see yours as a bus bar, then it will be better to ground on input resistor's ground side.
Old 1st June 2010, 05:31 PM   #3787
Franz Gysi's Avatar
Salas
I will keep it in my mind, should I need to debug hum or worse, motorboating.
Just edged the board, low quality
The toner transfer method does not always work as expected, but I will go now...
BTW: there is no (closed) circle ground! It is carefully separated between input, output and psu. And yes, the star point. But it will be easy to separate grounds of both channels when needed.
Franz
Old 1st June 2010, 05:34 PM   #3788
Salas's Avatar
Tin it with the iron and it will do fine. The speed of making beats aesthetics. Motorboating it will not show, simply because there is no loop feedback to create dangerous LF poles. Yes, not a closed circle, maybe I should have said peripheral or fence.
Old 1st June 2010, 05:40 PM   #3789
Franz Gysi's Avatar
Ahhh, yes, I have overseen R18 in your circuit.
I will look if I can apply a fix for this pcb or edge another one...
Franz
/Edit
there are still R9 and R11 decoupling following stages from the first one!
Old 1st June 2010, 06:01 PM   #3790
Salas's Avatar
Yes, that is why I generally skip it when using very low output impedance regs, especially when double mono. Its what it does with the other channel's 1st stage if there is just one reg that RC may prove helpful or not. But you can easily mod it receives from a central B+ node even as it is etched I guess with a knife and a jumper. There is space to move R12 next to R3, jumper the now R12, and cut the now 1st stage branch from the B+ distribution node.
Simplistic NJFET RIAAHide this!Advertise here!
