Simplistic NJFET RIAA
Old 31st May 2010, 12:59 PM   #3771
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Default Mu-metal shield & LSK380BL
@Rcruz
Arrived the mumetal shield 196mm x 315mm back self adhesive:
I'm doubting for balanced use the 2SK170BL or the LSK389BL, I have both on hand only need the measure the Idss in the LSK389BL. If I will use 2SK170BL will be all new & I suppose that will better sharing the same pcb the regs & the phono & if I will use LSK389BL will be less work because half work done. 20pcs photo:
Humm I'm enjoying only to mind in the work & the final success.
Old 31st May 2010, 01:03 PM   #3772
massimo is offline massimo  Italy
.... just because in a similar circuit optimized for k170 with IDSS 10.5 mA (very close then) you just modified R values.
Thank you!
P.S. Big strike today in Athens?
Old 31st May 2010, 01:16 PM   #3773
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Each values assortment on specific posts looked best on the simulator as it was posted. So better not try mix.
Old 31st May 2010, 04:47 PM   #3774
Franz Gysi is offline Franz Gysi  Switzerland
Franz Gysi's Avatar
Salas
Many thanks for your 11mA IDDS / 60dB gain simulation. It is very helpful, as I dont have the simulation software and all the needed knowledge behind it.
I will follow this path now, as I have all the needed parts.
Franz
P.S.
Any recommendations for a readily available shunt regulated pcb?
Old 1st June 2010, 08:26 AM   #3775
Franz Gysi's Avatar
I started the layout of my pcb.
The complete stereo circuit:
The pcb draft (every feedback and critic is welcome)
And the raw material:
Do the FET's require heathsinking?
Franz
Old 1st June 2010, 11:12 AM   #3776
No.
Felipe
Old 1st June 2010, 12:45 PM   #3777
Salas's Avatar
Franz
R1, 101 must be 1.3K. Made by 3 pieces 3K9 1W in parallel in the 15mA IDSS first circuit you asked. Its a single 2K2 2W in the 11mA circuit. R12,C9a,b Would be more useful if not feeding the whole, but reserved for first stage so it cuts interaction, the other stages have already.
Old 1st June 2010, 01:31 PM   #3778
juma is offline juma  Germany
juma's Avatar
... LM317 is limited to 37V...
No - the only 37V limit is the voltage difference between Vin and Vout.
So, as long as your Vin is not more than 37V higher than your Vout (and you respect the SOA) you can use LM317 at whatever absolute voltage value you wish (people often use it in tube circuits at 250V or 300V).
Old 1st June 2010, 01:49 PM   #3779
R.I.P.
what about during start up? Particularly is there is a discharged capacitor on the output.
Is there any data for the 317 subjected to transient voltage overload?
regards Andrew T.
Old 1st June 2010, 02:00 PM   #3780
juma's Avatar
It's always beneficial to carefully read the datasheet ...
Simplistic NJFET RIAAHide this!Advertise here!
