Simplistic NJFET RIAA - Page 371 - diyAudio
Old 22nd May 2010, 03:54 PM   #3701
massimo is offline massimo  Italy
Another older design by "La Maison de L'Audiophile" was using half 2SK240 (Idss 2mA), R in-to-gnd 100 ohm, 2 kohm on D, S connected to gnd, 1uF o/p cap (no R to gnd) and +12 VDC (Lead Acid Battery bypassed with 10.000uF elcap).
For 2SK240 with higher Idss, they suggested to add 47 ohm from S to gnd
Old 22nd May 2010, 06:02 PM   #3702
merlin el mago's Avatar
Gain x10, how many dB 20?
Old 22nd May 2010, 11:09 PM   #3703
Old 23rd May 2010, 01:55 AM   #3704
cjcc67 is offline cjcc67  Australia
Thank you that is exactly what i image. very simple. One problem though cannot find the fets in stock. Does anyone have some clues?
Old 23rd May 2010, 09:40 AM   #3705
Ask Spencer here: Toshiba 2SK170BL for sales
Old 23rd May 2010, 01:25 PM   #3706
excellent you guys are great. While i order the FET i might get some extra to try the Salas RIAA and the analog addicts. Do they nedd to be matched? If so what parameters are matched?
Old 23rd May 2010, 01:39 PM   #3707
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
IDSS should be matched. Each circuit published in this thread has a note for what IDSS is designed for.
Old 23rd May 2010, 02:00 PM   #3708
thanks Salas is that what the 8.5 - 8.7 refers to on the cct diagram of the low MC scheamtic? 8.5 to 8.7 ma Idss?
Old 23rd May 2010, 02:03 PM   #3709
Salas's Avatar
Yes. What is your now MM phono stage you want the MC pre pre for?
Old 23rd May 2010, 02:06 PM   #3710
@Salas
How many dBs?
Copyright 1999-2017 diyAudio
