Simplistic NJFET RIAA
Old 5th May 2010, 02:34 AM   #3671
psgr is offline psgr  United States
Merlin,
You prefer the Obligatos over the Auricaps, can you explain/elaborate.
I was thinking about getting auricaps for the output.
Pete
Old 5th May 2010, 03:02 AM   #3672
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by RCruz View Post
Where did you use those ?
Input load, and Riaa, judging from the values in the photo.
Old 5th May 2010, 10:41 AM   #3673
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Do you believe these would be suitable replacements for shinkoh in the cart load ?
Old 5th May 2010, 12:57 PM   #3674
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by psgr View Post
Merlin,
Pete
Hi psgr,
All depends what are you looking for, if you are looking for a warm/round sound without lost a lot of definition your election must be Auricaps or if you are looking for more resolution I will choose Obbligato's, that's are mine subjective opinion & of course all depends the system and your personal taste.
Both are very good caps at a very reasonable prices & worth the penny.
If possible try with the maximum voltage possible because subjectively there is a lot of difference of quality with more voltage.
Best,
Felipe
Old 5th May 2010, 12:58 PM   #3675
OK
Old 5th May 2010, 01:06 PM   #3676
Of course, in the cart load & in the RIAA, if you can afford use it minimum in the signal way or critic places.
You get more harmonics due to the low noise: transparent / clear sound, the bass more defined never lost & deep, the mids incredibles it' impossible hear more things & the highs simply perfects.
Versus Shinkoh the difference is that the mids & mids/bass are not inflated but with body, the bass is more controlled & deep, the highs aren't liquids like the Shinkoh but have more air or atmosphere for me are more real, is really difficult to express all in words.
Old 5th May 2010, 07:11 PM   #3677
nhinstruments
RCruz's Avatar
Thank you Merlin !
You could not have been more explicit.
I guess I must try those as well.... where did you get yours ?
Old 5th May 2010, 07:53 PM   #3678
From Michael Percy Audio, but you have to ask for ultra low TCR "nude" Z-foil TX2575 0.01% tolerance.
http://www.percyaudio.com/Catalog.pdf
Old 6th May 2010, 01:52 AM   #3679
maxpou is offline maxpou  Canada
maxpou's Avatar
Hi Guys,
I'm very confused, what's the good value of R3 in phonostage? I have many versions here and it have two values 45K and 47K. Thank you! Maxpou
Old 6th May 2010, 02:05 AM   #3680
Salas's Avatar
They tie with the first stage load resistor. So each schematic has its adequate one. Use the value on the schematic you build.
Simplistic NJFET RIAAHide this!Advertise here!
