Simplistic NJFET RIAA - Page 363 - diyAudio
Old 21st April 2010, 04:06 PM   #3621
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
That should have brought your DQ5 to GND DCV comparable too if you check. If yes, you are good to play.
Old 21st April 2010, 04:12 PM   #3622
merlin el mago's Avatar
Yes, 21.5V
It's all OK now? can continue with the test record?
Old 21st April 2010, 04:29 PM   #3623
Salas's Avatar
Old 21st April 2010, 04:33 PM   #3624
First to continue with the test record I will hear some records, thanks Salas
Old 21st April 2010, 05:56 PM   #3625
@Salas or somebody
To do the measurements with the test record I mind will be better to buy a decent & capable DVM not very expensive, could you recommend me some model & manufacturer, I'm lost.
Thanks for help.
Old 21st April 2010, 06:05 PM   #3626
Salas's Avatar
You have an oscilloscope, don't you? Read some online general guidelines on oscope by googling ''how to use an oscilloscope'' like that, and tweak some knobs until you see the 300Hz sinewave from track 5 on its screen Then you can compare for height between outputs. Opportunity to learn something useful.
http://www.youtube.com/watch?v=zQDuZ3a6HAE
Old 21st April 2010, 09:42 PM   #3627
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Now we are talking !!!
Old 22nd April 2010, 03:44 PM   #3628
YouTube - Basic signal measurements using an oscilloscope
Well I'm see a square wave using the scope.
Old 23rd April 2010, 12:14 AM   #3629
kerux is offline kerux  United States
Newbie question about Power transformer? I have been reading the pdf file that PSGR produced about the transformer required for a MM Cartridge. I have a shure m 97x, so I need the 24V 50VA transformer. Can I use the Hammond 166L24 which is a 24v 48VA transformer? It is cheaper from digikey than a 24v 50va toroidal transformer. Any input is appreciated. Thanks
Old 23rd April 2010, 12:22 AM   #3630
Salas's Avatar
Yes by all means.
Copyright 1999-2017 diyAudio
