Simplistic NJFET RIAA
Old 21st April 2010, 11:49 AM   #3611
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Leds alight, good progress. Now, you got the BC550 killed I hope and not the two JFETS under it. But it can be the other way or both. Change the 550 first.
Old 21st April 2010, 02:34 PM   #3612
merlin el mago is offline merlin el mago
merlin el mago's Avatar
I changed Q3 BC550, now the measurements are:
Leds-GND
Right 7.66 need to reduce to 7.3V?
Left 7.32 OK
V across R17
Right 328mV need to increase till 350mV?
Left 350mV
R10/Q2-GND
Right 8.4V need to increase till 10V?
Left 9.4V need to increase till 10V?
R1/Q3-GND
Right 7.4V need to increase till 11.5V?
Left 11V need to increase till 11,5V?
R7-GND
Right 8.6V need to increase till 10.3V
Left 10.3V
Drain Q5-GND
Right 21V adjusted with trimmer R6
Left 21V
Old 21st April 2010, 02:46 PM   #3613
Salas's Avatar
Do you have 45V B+ on both channels?
Old 21st April 2010, 02:57 PM   #3614
Measurements done loaded with RIAA:
Right B+ 42.1V
Left B+ 45.2V
Have I to increase or decrease till 45V B+ with RIAA loaded?
Old 21st April 2010, 03:04 PM   #3615
Salas's Avatar
When the system is loaded as it really plays, see that you got 45V B+ on both channels and then compare/trim DC points between channels.
Old 21st April 2010, 03:09 PM   #3616
OK adjust two channels for 45V B+
Old 21st April 2010, 03:24 PM   #3617
Salas's Avatar
OK. Trim the right referenced to the left.
Old 21st April 2010, 03:26 PM   #3618
45V B+ both channels:
Leds-GND
Right 7.3V
Left 7.32
V across R17
Right 331mV
Left 351mV
R10/Q2-GND
Right 11.53V
Left 9.94V
R1/Q3-GND
Right 11V
Left 10.63V
R7-GND
Right 11.57V
Left 9.99V
Drain Q5-GND
Right 17.5V
Left 21.1V
Old 21st April 2010, 03:36 PM   #3619
Salas's Avatar
Trim your right R6 trimmer to get 9.94V on R10/Q2.
Old 21st April 2010, 03:53 PM   #3620
Done both 9.94V
Simplistic NJFET RIAAHide this!Advertise here!
