Simplistic NJFET RIAA
Old 4th April 2010, 12:31 PM   #3491
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
The passive filter is very prone to noises due to parasitic capacitances.
When I use perfboard, i get the best results by removing the unused copper islands between the riaa filter components.
I also notice that the board must be totally free of flux in that area otherwise some noise appears.
PS: I read about submerging the built board in isopropil alcool would get rid of the flux completely but I did not try it because I am afraid the alcool might affect the components.
Old 4th April 2010, 12:39 PM   #3492
massimo is offline massimo  Italy
I use an old toothbrush to remove flux. Isopropil alcool is oK, but sometime not enough. C2HCl3 (trichloroethylene) or similar is more aggressive and components safe. It might remove printing on caps sometime.
Old 4th April 2010, 12:45 PM   #3493
nhinstruments
RCruz's Avatar
I will search for C2HCl3 (trichloroethylene).
I use a stiff paint brush but sometimes the flux passes to the component side and sticks (particularly under the caps)... Can I submerge a board on C2HCl3 (trichloroethylene) or should I be afraid that it would soak some components ?
Old 4th April 2010, 12:54 PM   #3494
I think EU laws prohibits trichloroethylene, but some stain remover are also good. Ask your wife/mother
I only used old toothbrush to clean solder side, never submerged pcbs, thus no idea, but useless IMO.
Old 4th April 2010, 02:49 PM   #3495
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by merlin el mago View Post
Massimo, I am grateful for your advice (believe me I dislike use more cable than necessary & solder more than necessary), wich one of both will be the best star grounding.
Massimo, wich will be the best of two star ground?
Old 4th April 2010, 03:15 PM   #3496
1st option, I presume.
Old 4th April 2010, 03:54 PM   #3497
Grazie caro / Kind thanks
Old 4th April 2010, 04:05 PM   #3498
Ricardo, I use this with good success
Old 5th April 2010, 11:08 AM   #3499
nhinstruments
RCruz's Avatar
Thank you Merlin. I have seem that before but never tried it.... I will have a go now
Old 5th April 2010, 11:56 AM   #3500
Ricardo, I am sure that's distributed in Portugal too, because the instructions are wroted in Portuguese & Spanish (so Iberian product).
Simplistic NJFET RIAAHide this!Advertise here!
Copyright ©1999-2017 diyAudio
