Simplistic NJFET RIAA
Old 29th March 2010, 11:25 AM   #3441
capritar is offline capritar  United States
Thanks so much. Very useful info on audio capacitors. It gets bewildering, i find. I may end up with my own cap collection, lol.
Old 29th March 2010, 01:14 PM   #3442
maxpou is offline maxpou  Canada
maxpou's Avatar
Originally Posted by Salas View Post
2- 5.6-6.8uF
3- B+ to ground directly.
Thank you Salas very appreciated.
Originally Posted by massimo View Post
You can order them from HK through eBay. Search for Obbligato caps and Obbligato premium
Thank you too for info Massimo.
Maxpou
Old 30th March 2010, 02:06 PM   #3443
merlin el mago is offline merlin el mago
merlin el mago's Avatar
@Salas
Still I have some noise, posible as you said before due to mine bad design in the RIAA connections between components, mine question is:
Have I any way or general rules to connect the components or to ground to avoid the noise, as per your kind advice I use coax shielded cable for signal & I grounded the gnds of the input RCAs by a 10nF to the chassis also grounded to gnd chassis the negative output of the regulator.
Thks in advance
Old 30th March 2010, 02:09 PM   #3444
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
You mean some hum left? After you used the second psu it stayed the same or added some? Now you have two points from regs neg to chassis. If it was better before, try to have one common point for both to chassis. Also close the box if its open. Did you do the remote by now?
Old 30th March 2010, 03:07 PM   #3445
Yes, after 2nd psu stayed the same hum. About install one common point for both to chassis a do it before & the hum is more, better 2 points chassis for the neg. reg. Always the box is closed but without screws, no I don't have Rs.
Old 30th March 2010, 03:13 PM   #3446
Salas's Avatar
So it is best with two points. Its a hands on thing to reduce. Sometimes a resistor like 10R can work between both or one point to chassis. Is something close to it that has Tx, mains cable near the inputs etc.
Old 30th March 2010, 03:22 PM   #3447
So one 10R between neg reg & chassis, ok?
Old 30th March 2010, 03:42 PM   #3448
Salas's Avatar
Yes, to one or both and listen. Experiments. Nobody can know the hum points beyond generalities if not there.
Old 30th March 2010, 03:46 PM   #3449
Ok I will experiment with resistors an AC cable far from inputs I will let you know, thks.
Old 30th March 2010, 03:55 PM   #3450
Salas's Avatar
What AC cable? We were talking -reg to chassis. Is AC running near too?
Simplistic NJFET RIAAHide this!Advertise here!
