Old 17th March 2010, 11:46 AM   #3341
RCruz is online now RCruz  Switzerland
RCruz's Avatar
Originally Posted by merlin el mago View Post
Ricardo for R3 you suggested:
Left 45K473
Right 45K675
Salas for R3 suggested:
Left & Right 46K017
I don't know a lot of about electronics but I'm very curious, why are different values?
Salas sugestion was made before we knew about your true riaa values.
The three resistors R1 R3 and R5 interact so when you // 1M4 on the Left, you do not get only 45k473.... the riaa circuit "sees" 46k755.
If you input this value on the calculator http://www.kabusa.com/riaa.htm
you will get caps values that will sound acording to Lipshitz
For the right channel, my best bet would be // 1M9 so the final R would be 46k684.
Experiment with 2M as suggested by Salas, than finetune using lower values until you get the best results and let me know your findings.
After we set the correct values we can think about replacing with good resistors.
Old 17th March 2010, 12:05 PM   #3342
RCruz's Avatar
This is an aproximation based on my listening experiences and following closely all of Salas sugestions.
IMO The calculator kabusa can only be correctly used if the input resistor value is calculated acording to this formulae: R equals (R1 + R3) paralleled with R5
R =1/((1/(R1 + R3)+(1/R5))
Old 17th March 2010, 12:15 PM   #3343
massimo is offline massimo  Italy
George cooks, Merlin cooks, Massimo cooks: should we open a Mediterranean Restaurant?
The very best from Greek, Spanish (OR Catalan if you prefer ) and Italian cusine!
Old 17th March 2010, 12:39 PM   #3344
merlin el mago's Avatar
Well the real problem now is not the cook, is where open our famous Mediterranean Restaurant
Old 17th March 2010, 12:51 PM   #3345
You forget Rcruz (cooks mathematics) & Salas(cooks electronics)
Old 17th March 2010, 01:01 PM   #3346
As per Salas design will be?
R = 3.300+47.000 // 1.000.000 = 47.891 R1 input Kabusa calculator
Kabusa R1 47.891 - R4 6.963 - C2 45nF664 - C3 15nF661
R4-C2-C3 are Salas schematic
So I suppose that in the design select closest standard values.
Mine real situation without changing nothing is?
Left
R = 3.300+47.000 // 1.130.000 = 48.156 input Kabusa R1
Kabusa R1 48.156 - R4 7.002 - C2 45nF412 - C3 15nF574
Right
R = 3.300+46.800 // 998.000 = 47.705
Kabusa R1 47.705 - R4 6.936 - C2 45nF842 - C3 15nF722
I am really enjoying.
Old 17th March 2010, 01:41 PM   #3347
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Well, I already have a restaurant with greek food in my hotel!
If any of you comes here, I' m offering a free lunch or dinner.
Old 17th March 2010, 01:59 PM   #3348
Wow, you're living in Paradise.
Old 17th March 2010, 02:19 PM   #3349
Nearly..... in a Golden hotel, with a Golden restaurant over the Saronic Gulf
Ricardo can bring his Grandma's recipies for Bacahlau and Salas, the Master, will be our maître....
Old 17th March 2010, 02:40 PM   #3350
RCruz's Avatar
Left
Right
As you can see, with your actual setup R4 should be 7k
With your actual values the sound will be recessed.... You can either increase R4 or reduce R3 as I sugested before. (IMO The easier way)
Copyright ©1999-2013 diyAudio
