| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#3261 |
EB do a Phono with fets with a gain of 73dBs, only a master can do
#3262 |
diyAudio Chief Moderator
Does he give its noise density?
#3263 | |
Ricardo,
Please note in bolt: Quote:
.So it's not necessary 68pF to reach the 16nF for C3, I will remove in both channels? Tomorrow I will let you know exact values of R1. Not I haven't got more resistors I have to order more, please be sure with values as you know this kind of resistors are expensives, thks. |
#3264 |
From data-sheet Erno Borbely Web:
Circuit description. The schematic of the EB-199/320 is shown in fig. 2. The first amplifier is a linear one, using 4 pairs of low-noise Cascoded JFETs at the input. The second stage is also made up of low-noise Cascoded JFETs. The output stage is a complementary MOSFET source follower. The gain can be changed with the feedback resistors to 20, 30, 40 and 49dB. R28-C15 provides the high frequency roll-off of the RIAA equalization. The second amp provides the bass boost of the RIAA curve. Except for the input stage, which is a complementary differential Cascode circuit, the amplifier has the same topology as the input stage. The second amp has a gain of 24 dB at 1 kHz, making a total gain of 54 and 64-73 dB for the phono preamp. Due to the high gain at low frequencies (64-93dB!), both stages are using servo control for DC-offset. The offset control is provided by low-noise JFET-input opamps. The opamps are supplied with ±10V from shunt regulators Typical Specifications. Gain: 1st stage: 20, 30, 40 or 49dB (20dB for MM) 2nd stage : 24dB THD 3VRMS/1kHz: 0.002% Max. Output voltage: approx. 9VRMS Risetime (without RIAA network): 0.3/0.4usec RIAA Accuracy: better than 0.2dB Equivalent input noise: <100nV, 20Hz-30kHz Secret questions ask directly to Erno, but for sure don't tell you , I'm sure that the real Merlin The Wizard is Erno & his magic.
#3265 |
#3266 |
I would go with bipolar low rbb head amp if I had a 0.1mV cart, still.
#3267 |
I would prefer hear both face to face & after I will take mine decission.
Still have the Linn Arkiv 0.16mV, but I see very complicated the designs of Syn8 & Gerard Mpp project seems never finishing. Last edited by merlin el mago; 15th March 2010 at 10:33 PM. |
#3268 |
Ricardo,
I have a couple of Shinkohs 999K 2W, also I have a couple of Caddocks MK132 one 1,002Meg & the other 1,001Meg, wich of both will be better for R5? Last edited by merlin el mago; 15th March 2010 at 10:29 PM. |
#3269 |
#3270 |
Mem de CB
| Page generated in 0.63312 seconds (100.00% PHP - 0% MySQL) with 10 queries |
