Old 11th March 2010, 11:38 PM   #3141
massimo is offline massimo  Italy
Not that important, but...
Take a DVM, set for max VAC, probes (forget colour) on pin 2 and 3 of the Xfrm: you get something around 225-235 VAC. That is Vin
BE CAREFUL! High Voltage! Don't short anything!
Then set the DVM for 200 VAC, probes on pin 6 and 7 and you get the Vout
Assuming you've wired the Xfrm as per the drawing you attached.
P.S. the Preamp should be on
P.P.S. you have now two shunt regs connected to one Xfrm, right? Thus total I should be around 2 * 200 mA or so....
Old 12th March 2010, 11:39 AM   #3142
merlin el mago's Avatar
If I understand well, you want to know the secondary voltage with the phono connected, ok?
Old 12th March 2010, 11:41 AM   #3143
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
He wants to see the regulation. How much it drops from nominal when well loaded. Now you must have one Tx giving about 300mA to a pair of regs, right? Thats a tell tale situation enough.
Old 12th March 2010, 11:56 AM   #3144
Why want to know how drops from nominal when loaded, possible to know the perfomance of the Tx, if its capable to follow giving the 40V when loaded?
Old 12th March 2010, 11:59 AM   #3145
Salas's Avatar
Yes, and maybe he wants to know where it goes when the secondaries go series like its needed here. You know Italians, always never worried about top performance in gear and chicks. Ducati, Ferrari, Monica Bellucci etc. Always about compromising are those guys...
Old 12th March 2010, 12:10 PM   #3146
nicoch58's Avatar
Old 12th March 2010, 12:17 PM   #3147
Salas's Avatar
Don't grin up on me you sneaky you! Not to mention you know zero fashion or the cheap indifferent quality of food and wine, pasta and dairies you propose to the world...
Old 12th March 2010, 12:31 PM   #3148
Seems the only way to get the perfection nothing to do with compromising.
I love Ferrari+Alonso, any kind of pasta, pizza, italian coffe (please no other like the expresso), capuccino, Monica Belluci too. I visit Italy several times & I enjoyed other fine things like carpaccio, grana padano, funghi porcini & many other delicatessen, don't forget fashion are the best. The bad thing is traffic when goes more to the south more bad, Milan seems perfect when you drive in Rome, butwhen you drive in Napols or Reggio Calabria you live in other dimension.
Old 12th March 2010, 12:34 PM   #3149
The only data not specified by Hammond
Old 12th March 2010, 12:37 PM   #3150
I'm an open book for you! (as we say in Italy)
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
jybe
Page generated in 0.16956 seconds (62.11% PHP - 37.89% MySQL) with 11 queries
