Simplistic NJFET RIAA
Old 19th February 2010, 12:34 PM   #3071
maxpou is offline maxpou  Canada
maxpou's Avatar
Hi Salas,
thank you for your schematic it's very appreciated. I have some questions for you.
1- What is the color of LEDs used in the PS?
2- It's very necessery to match Q1 and Q7?
thank you! Maxpou
Old 19th February 2010, 01:40 PM   #3072
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
1. Greens will do OK.
2. Not exact match necessary, but keep em the closest you can.
Old 19th February 2010, 02:33 PM   #3073
audiodesign is offline audiodesign  Italy
Banned
Send a message via MSN to audiodesign Simplistic NJFET RIAA
Salas,
Have you a good high voltage regulator to use for this project ?
http://www.diyaudio.com/forums/group...ml#post2090930
Old 19th February 2010, 03:10 PM   #3074
Salas's Avatar
I have the simpler simplistic. Has its own thread in power supplies. I see from the photos in your link, its already there.
Old 19th February 2010, 03:11 PM   #3075
massimo is offline massimo  Italy
Simplistic Mosfet HV Shunt Regs
Old 21st February 2010, 03:27 AM   #3076
maxpou's Avatar
Thank you Salas,
I will give you news as soon as possible. Maxpou
Old 8th March 2010, 10:13 PM   #3077
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Snowing all day, internet has gone till now, AC electricity going off, going on every half hour, all living in Europe
One channel LED's lit & voltage between GND & Q3 (BC550C) ok with 7.2V
The other channel LED's lit but voltage between GND & Q3 (BC550C) is 7.86V?
Can I use the NJFET RIAA or I have to wait until get 7-7.3V?
Old 8th March 2010, 10:37 PM   #3078
Salas's Avatar
You can. Still near. Just find 1-2 LED that are low to exchange and drop down the happier side, in the next days. For to have excellent first stage voltage match.
Old 8th March 2010, 10:44 PM   #3079
It's really strange, I have matched the LED's in both channels with the same voltage across: 7.25V?
Old 8th March 2010, 10:46 PM   #3080
Salas's Avatar
Yes but the two Jfet CCS for LEDs may be producing different currents or the LEDs behave differently at this current level. In the end, when everything works OK, I will guide you on how to match the output levels for both channels by using a test record and your DVM. That is what really matters. Is it playing music yet?
Simplistic NJFET RIAAHide this!Advertise here!
