Simplistic NJFET RIAA
Old 1st February 2010, 12:26 PM   #3051
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
As I always needed small low radiation TX, my experience is based only in toroids.
I will keep it in mind for future projects
Old 4th February 2010, 11:11 AM   #3052
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by Salas View Post
Mine is Mission 774 (ULM class) and I measured 8.5 Hz Fs with the test disc for the combo. Weird cart.
How did you measured the Fs?
Old 4th February 2010, 11:27 AM   #3053
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Test disc, low resonance sweep track, phono out to FFT.
Old 4th February 2010, 07:52 PM   #3054
nhinstruments
RCruz's Avatar
Two shunts are definitively worth.
Even with only one tx and one rectifying bridge followed by two smoothers the difference for 1 shunt is producing much better separation between channels... The image grows laterally and the instruments are better focused.
Care must be taken with GND. To avoid hum at maximum, star earth linked to mains earth and case is connected to both shunts (-).
Do not connect the rectifier bridge directly to GND as this intruduces more hum.
Ricardo
Old 5th February 2010, 08:35 AM   #3055
Joao@AltheaMusica is offline Joao@AltheaMusica  Switzerland
Ricardo
I'd recommend a shunt for each stage... and for grounding, use star ground to the negative rail of each shunt.
Um bom fim-de-semana
Joao
Old 16th February 2010, 10:50 AM   #3056
Can I use these leds?
Digi-Key - 511-1206-1-ND (Manufacturer - SLI-325YCT31W)
Old 16th February 2010, 10:52 AM   #3057
Salas's Avatar
Yes, electrically they are OK.
Old 16th February 2010, 07:01 PM   #3058
nhinstruments
RCruz's Avatar
Hi Joćo
You are correct... I had trouble earthing the (-) of the rectifier bridge and opted to use floating earth... (it works in this case) but after some studying I decided to ground the (-) of both shunts and that produced the best results.
Did you build one of these ?
Ricardo
Old 17th February 2010, 08:39 AM   #3059
Originally Posted by RCruz View Post
Hi Joćo
Ricardo
No I didn`t build one yet. My expericence is from my tube amps and as well what my old professors - one of them was a designer of high frequency amps & tuners - told me from the experience of her works.
I've got my transistors and will nuild a version from Salas phono amp with a 600 ohm LCR-RIAA. It will be interesting because I'm building up my new tube phono stage with LCR-RIAA as well!
Old 17th February 2010, 11:55 AM   #3060
nhinstruments
RCruz's Avatar
Lcr riaa ?
Simplistic NJFET RIAAHide this!Advertise here!
